Author Topic: 2.2/2.6 lambda interchangeable?  (Read 1758 times)
omegod
  • liverpool
    • 2017 Seat Ateca
« on: 15 August 2013, 20:13:23 »
Howdy,
Will any of the 4 working lambdas off my 2.6 breaker fit my 2.2 ??
Re: 2.2/2.6 lambda interchangeable?
« Reply #1 on: 15 August 2013, 20:17:17 »
Not interchangeable
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #2 on: 15 August 2013, 21:29:18 »
FFS !!! cheers rob ::)
« Reply #3 on: 15 August 2013, 21:46:15 »
Are all 4 lamdas on 2.6/3.2 the same as each other apart from the length of the cables ? Im reasonably sure they are,but would like to be 100%. :)
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #4 on: 15 August 2013, 21:53:11 »
4 pots have different lambdas to the V's.  :y
« Reply #5 on: 15 August 2013, 21:53:57 »
Here you go Albs :)
2.6i 24v - Y26SE Position 1; With Automatic Transmission    9195606
2.6i 24v - Y26SE Position 1; With Manual Transmission    9199470
2.6i 24v - Y26SE Position 2; With Manual Transmission   9199470      (>Ch.) 21059096
3.2i 24v - Y32SE Position 1; With Automatic Transmission    9195606
3.2i 24v - Y32SE Position 1; With Manual Transmission     9199470
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #6 on: 16 August 2013, 07:25:28 »
I think thats a yes albs :)
Hoof'land storeman.
« Reply #7 on: 16 August 2013, 10:56:56 »
Pretty certain mine has a mix of manual and auto ones fitted at the moment :y as long as they have the same number of wires/matching plugs cannot see it being an issue...
Four pot ones are probably calibrated for the four pots gas mixture :-\ technically, the sensors on the V6 only measure the output of three cylinders :y
« Reply #8 on: 16 August 2013, 12:27:40 »
The only difference between the auto and manual ones is the wire length.
Lambda's measure 02 levels, nothing more so no need to have a difference dependent on the cylinder qty etc.
What may be different is the 02 sensor material (there are a few types including wide band) and this will be ecu dependent.
I would go as far as saying, try one.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #9 on: 16 August 2013, 13:22:16 »
Earlier post here, a few weeks back seems to suggest there the same, except for the cable lengths.
http://www.omegaowners.com/forum/index.php?topic=117037.msg1481086#msg1481086
