Author Topic: Tie Rod Hits Wheel  (Read 1658 times)
JayMV6
  • Reading
Tie Rod Hits Wheel
« on: 17 August 2013, 11:38:47 »
Morning Folks. Put new shocks and wishbones on my car and used a whole steering bar from another omega including track rods (Was much better condition then mine and free). Took it to get 4 wheel aligned and afterwards noticed on full right hand lock the wheel rubs on the track rod. He did have to heat the drivers side up to adjust it. So my first thoughts are Hes bent it slightly after having to use force. New one is ordered and just waiting to go pick it up to fit it but was wondering if theres anything else that could be the cause? or if anyone else has had this problem?
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: Tie Rod Hits Wheel
« Reply #1 on: 17 August 2013, 11:51:07 »
You sure that it's the correct tie-rod? :-\
Each one is cranked forwards, and are 'side-specific'  ;)
JayMV6
  • Reading
« Reply #2 on: 17 August 2013, 11:55:51 »
yeh i know this is 100% as they gave me the wrong side hence why im waiting for the part. Do they get quite close to the wheel normally? I do have 18's on but it didnt do it before with my original set up and only does it on the right hand full lock.
JayMV6
  • Reading
« Reply #3 on: 17 August 2013, 16:54:37 »
New Track Rod worked well.  :y
« Reply #4 on: 18 August 2013, 08:27:16 »
Don't forget you now need it set up again ;) Although if you managed to change the track rod without disconnecting anything else (which you should have done) then just tracking will suffice  :y
JayMV6
  • Reading
« Reply #5 on: 20 August 2013, 17:55:57 »
Yeah took it staight down there. No matter how much u try match up with the old one it never works  :y :y
