Halfords Brake shoes?
Started by tunnie, 20 August 2013, 19:29:20
So i need new brake shoes for the 2.2, as mine fell apart on inspection  ::)
General thoughts appear to be Halfrauds due to Vx's high cost on these, also helps I've got trade access, but searching online and popping to store, found no brake shoes for the Omega? Although in the shop they had Shitron AX on the shelf  :o  ;D
Lists nothing based on either car reg:
Slightly shot shoes:
That's why I use 'Park' ...... so I don't wear my brake shoes out  :y :y :y :y
(joke!!!!!!)
Might I politely suggest you shop elsewhere ;D
Kids these days.... Have to do everything for them ::)
I can't grumble, they are original to the car  ;D
Reason for asking is research on previous threads show loads people quite happy with Halfrauds sourced ones. Also handy as its close to work
Go straight to your local factor, and they'll be in stock, which is far more convenient and helpful ;D
biggriffin
been down the lokal car park doing hand brake turns and overheated them, now they fall apart, and he says they just got old, :)
use the cheapest ones you can, but you will anyway,  :y dont forget fitting kit.
Hoof'land storeman.
Kit? Thought just shoes? Planning on re-using springs ect.
With 25% discount on europarts, its £22 delivered. Will do me
Broomies Mate
Quote from: Andy B on 20 August 2013, 19:33:47
(joke!!!!!!)
^^^^^ This, without the joke!
Only spotty teenagers need handbrakes when impressing schlaaaaaaags at the local McDonalds.  THATS A FAKT!
I know it's factual, because I've witnessed it.
Where does one buy a 'handbrake' from?  :-\
biggriffin
the springs will be as old as the shoes,if not older, and so will the clips.
scrimp now pay more later...
Hoof'land storeman.
Quote from: biggriffin on 20 August 2013, 19:59:25
Guide only suggests replacing if damaged?
http://www.omegaowners.com/forum/index.php?topic=90580.0
Springs, like shoes I highly suspect are original to the car.
biggriffin
Quote from: tunnie on 20 August 2013, 20:02:32
up to you just advising what is best, and they only cost £10 for both sides,
Hoof'land storeman.
Webby the Bear
if the springs are anything like mine on the ford you'll want to replace them to cover for if you get it wrong and bend 'em as theyre under a lot of tension
RIP Paul Lovejoy
Quote from: biggriffin on 20 August 2013, 20:14:43
Cheers, cannot appear to find spring kit though. Found standard pad kit, but not drum kit.
http://www.eurocarparts.com/brake-accessories-and-brake-fitting-kit
Quote from: dbug on 20 August 2013, 20:52:47
Quote from: tunnie on 20 August 2013, 19:43:41
http://www.eurocarparts.com/mobile/handbrake-shoes
Halfrauds was half the price on trade :(
http://www.ebay.co.uk/itm/VECTRA-OMEGA-ASTRA-CALIBRA-CARLTON-HANDBRAKE-SHOES-/400019656784?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5d23079050
Cheers, so around £16 delivered, un-branded though. Think its worth extra fiver from eurocarparts.
Quote from: Webby the Bear on 20 August 2013, 20:58:03
Where did you get your springs from mate?
