Holts Radweld. Anyone used it?
Started by Webby the Bear, 25 August 2013, 09:48:17
chrisgixer
Quote from: tooleater on 25 August 2013, 22:10:22
not 100% sure,but either way he looked like he new what he was doing,shame about the poor barstewards that would be buying as they only deal with there own,such lovely people >:(
He might be flushing it. ...might. :-\
henryd
Quote from: Lazydocker on 25 August 2013, 20:57:17
I've always found K-Seal better. The radweld will work on small holes but does have the potential of causing issues.
K-Seak only sets where it meets air. That doesn't mean it's problem free but I find it more effective and less likely to cause a blockage :y
However, first advice would be to get the leak sorted ;)
+1,never had an issue with K seal,about the only one I would use though :y
other rides
If Radweld was such a problem, they'd have gone bust ................... I do get the suggested reasons as to why not  ;)
I had a weeping core plug....And radweld sorted it until the heads were done.
That said my heater matrix needed flushing every month or 2 to provide heat afterwards!
mantahatch
#34
Sorry . to early in the morning.
Webby the Bear
Thanks for the input guys. As I stated initially i'm not in to bodge jobs. Would like to get it sorted properly.
i'm going to follow Symes's advice and get a new drain plug... if that doesn't work i'll pop an extra 'o' ring on and see if that does the trick.
IF it doesn't I presume it's new rad then... just to cure a dodgy drain plug? :(
is the consensus that this stuff is useable.....to save me buying a new expensive rad.....
http://www.eurocarparts.com/ecp/p/car-accessories/engine-oils-and-car-fluids/car-additives/cooling-system-treatment/?542770100&0&cc5_171&gclid=CPzc5MConbkCFbQetAodnVMACQ
RIP Paul Lovejoy
Webby the Bear
well mums been driving it around and had a look today and theres definitely no leaks. i wonder if it was simply dripping from where i accidentally dumped a loada coolant out when bleeding as it went all over the engine bay  ::)
I got a spare drain plug just in case.  :y
RIP Paul Lovejoy
symes
Quote from: chrisgixer on 25 August 2013, 20:52:16
I heard a rumour Jaguar used it in all their new cars at one time. But that's quite possibly bollards, I wouldn't know.
Wasn't that meant to have been Bar's? Actually, yes .. a quick google shows that the handbook even told you to add a bottle if you changed the radiator!
Proper British engineering.. if the fluid isn't leaking, it's probably empty ;D
Shackeng
Quote from: aaronjb on 27 August 2013, 13:38:56
I thought it was recommended to add it to my Jag XK6 coolant system at some service intervals, but I may be dreaming, it was about 30 years ago. :-\ :-\ :-\
PS Still got a bottle on the shelf from that period, so I bought it for something.!
Webby the Bear
RIP Paul Lovejoy
Quote from: Shackeng on 27 August 2013, 17:17:21
The bit I read was in an XJS manual, but similar vintage  :y Knowing Jaguar I wouldn't mind betting my XJ12 (XJ40) manual says the same thing.. ;D
Shackeng
I can't find it in the Jag XJ6 Haynes book, but I seem to recall it was in the genuine Jaguar Service Manual which I let go with the car. :-\ :-\ :-\
