Author Topic: ICV  (Read 2504 times)
karlo
  • Rochester Kent
    • 1995 omega B 2.5 V6 saloo
ICV
« on: 28 August 2013, 20:14:41 »
Hi can anyone tell me what an ICV is please
Re: ICV
« Reply #1 on: 28 August 2013, 20:16:30 »
Idle Control Valve  :y
Re: ICV
« Reply #2 on: 28 August 2013, 20:17:23 »
Too slow - Idle Control Valve ;)
Re: ICV
« Reply #3 on: 28 August 2013, 20:22:09 »
Your question would have been answered in your thread, no need to start a new one. We are quite active here, loads of questions can be asked in the same thread  :y :y :y
Re: ICV
« Reply #4 on: 28 August 2013, 20:35:42 »
Speak for yourself. :P ;D
Re: ICV
« Reply #5 on: 28 August 2013, 20:39:32 »
Look who's talking "Mr always on here" - now standing at 117d 18h 2m  :o  ;D  ;D
karlo
  • Rochester Kent
Re: ICV
« Reply #6 on: 28 August 2013, 20:49:36 »
Thanks I am new here so I'm sorry if I haven't complied to your way of doing things, just trying to get the beast from lurching when it stops, Its a little annoying that's all, apart from that car runs like a Trojan
Re: ICV
« Reply #7 on: 28 August 2013, 20:51:44 »
Don't worry, you can ask all kinds of questions in the thread  :y
2.5 is rock solid engine  :)
karlo
  • Rochester Kent
Re: ICV
« Reply #8 on: 28 August 2013, 20:54:09 »
I've  cleaned the ICV, BUT ENGINE STILL REVS WHEN ITS GOING TO STOP, any suggestions
Re: ICV
« Reply #9 on: 28 August 2013, 21:03:07 »
An air leak of some sort springs to mind.It might be worth spraying a little carb cleaner around different areas of the engine bay and see if the revs rise.If they do,youve found the area of the leak. :y
Re: ICV
« Reply #10 on: 28 August 2013, 21:03:47 »
I may be on here,but most of the time Im in no way active. :P ;D ;D
karlo
  • Rochester Kent
Re: ICV
« Reply #11 on: 28 August 2013, 21:06:35 »
Ok thanks Ill try that
Regards
amba
  • Medway towns
    • German V6
Re: ICV
« Reply #12 on: 28 August 2013, 21:13:13 »
Might also be worth just checking the throttle cable hasn,t got any frayed wire strands as that could restrict it from pulling back when releasing throttle.
Pop off the cable from the ball joint on the throttle body and give it a good check ,then apply little bit of grease to the ball end when replacing .
Does sound more like an air leak if you have given the ICV athorough clean..assume you applied a few drops of light oil on the internal slider when refitting....as per guide.
