Author Topic: Still a bit of Mayo?  (Read 1325 times)
SandBoy
  • King's Lynn
    • 51 Plate 2.2CD
« on: 29 August 2013, 09:15:51 »
As you are all aware  ::) we done the HG on goldie the other week,I cleaned the head best I could.
Just checked and there is still a trace of mayo on the dip stick and filler cap :-\ Is this normal?
I intend to run her for a couple hundred miles and then change the oil and filter again, am I right in thinking this will clear the cream? :-\
PS Thankyou to omegod for the strut clips,all sorted :y
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
Re: Still a bit of Mayo?
« Reply #1 on: 29 August 2013, 09:35:17 »
If you had a lot of mayo before the CHG change then I wouldn't be surprised to find a little still in there.
Provided it's not still consuming coolant then I'd take it for a decent run (an hour or so) and see how it is after that - getting the oil nice and warm should clear up any lingering mayo.
I would certainly change the oil again after a few hundred miles - for the cost of a tub of oil, it's not worth taking any chances.
SandBoy
  • King's Lynn
    • 51 Plate 2.2CD
« Reply #2 on: 29 August 2013, 12:01:29 »
Cheers,the coolant levels are all ok and temp is where I would expect it to be :y
Plan to do 2 oil + filter changes within 600 miles and then put in good stuff,I am reckoning that should give her a good clean out :-\
Trouble is now,unless the doctors let me back driving again next month,I will have to get rid :'(
Done all the work and now I have to get my mate to chauffeur me around :-[ just itching to get behind the wheel 8),not a very good passenger when the car is mine >:(
« Reply #3 on: 29 August 2013, 12:23:54 »
Check the breathers are clear, too.
SandBoy
  • King's Lynn
    • 51 Plate 2.2CD
« Reply #4 on: 29 August 2013, 13:11:53 »
Cheers Kevin , will do :y
Page created in 0.023 seconds with 16 queries.
