Author Topic: Gardening question  (Read 1400 times)
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
Gardening question
« on: 30 August 2013, 12:46:41 »
Hi all you green-fingered types :y
Simple question.....how do you get rid of ivy. Just got loads of it at the back end of the garden. What can I spray on it.
I have a big bottle of neat sheep dip in the garage, if I dilute it a bit and spray that on it, will the tar content kill the plant. Got to be a bit careful, because swmbo has some shrubs there, and my temporary aviary is close by.
Here's hoping :y
Tony
Re: Gardening question
« Reply #1 on: 30 August 2013, 12:53:52 »
Fire.
.. or can you cut it off at the ground and let it die?
Hang on.. What am I doing giving gardening advice? :o
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
« Reply #2 on: 30 August 2013, 13:04:40 »
Fire.
Seems a bit extreme Kevin ???
I don't suppose Jamie has asked your opinion in the near past, on how to achieve more garage space ;D ;D ;D ;D
cleggy
« Reply #3 on: 30 August 2013, 15:28:28 »
You can either cut it off at the base and let it die or spray it with Glyphosate weedkiller to kill it and the roots
SandBoy
  • King's Lynn
    • 51 Plate 2.2CD
« Reply #4 on: 30 August 2013, 15:31:22 »
Or cut it off at the base and put black disinfectant or diesel  on it,that's what killed mine :y
« Reply #5 on: 30 August 2013, 16:48:39 »
 Last time i killed a plant i drilled its root ball and filled with paint stripper , its not grown back in 7 yrs  ;D
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #6 on: 30 August 2013, 16:59:38 »
I'll have some spare antifreeze soon i'll need to get rid of  ;D
« Reply #7 on: 30 August 2013, 17:05:13 »
cnj
  • ludgershall
    • 2.2 Manual CD(51 plate)
« Reply #8 on: 30 August 2013, 17:53:49 »
personally I would cut the stems twice so as you have a gap between, and then paint neat glysophate/roundup over the stems coming from the ground. that way you have no problems with spray drift, and your good lady's plants are safe ! that's what we do for Hampshire schools.
