Author Topic: Crankshaft sensor  (Read 2147 times)
Bob G
  • Gloucester
Crankshaft sensor
« on: 30 August 2013, 21:08:52 »
Right found its location, got the new one, but has anyone ever done this job? I ask as it seems to disappear behind the air con compressor, Pains book says remove the left engine mount, seems excessive.  Help needed please  :(
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
Re: Crankshaft sensor
« Reply #1 on: 30 August 2013, 21:19:02 »
Is this on a 4 pot or V6.  :-\
I'm only familiar with V6's.
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #2 on: 30 August 2013, 21:25:55 »
V6 for me too.
Bob G
  • Gloucester
« Reply #3 on: 30 August 2013, 21:28:09 »
sorry should have said 4 pot f/l
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #4 on: 30 August 2013, 21:31:05 »
Never heard of one of these going before :-\ :-\
Bob G
  • Gloucester
« Reply #5 on: 30 August 2013, 21:42:36 »
quite a post on here about it (mine) code is the one for it, also been cutting out during driving very scary, last week it red lined itself on kick down, then went to limp and no revs, all very frustrating
symes
  • oxford
    • R reg 940 volvo
« Reply #6 on: 30 August 2013, 21:54:38 »
Remove engine mount and you can see/get to it :y :y :y
Bob G
  • Gloucester
« Reply #7 on: 30 August 2013, 21:58:50 »
Cheers, what a palaver for something held in with one screw, engine mount easy to do is it? :(
« Reply #8 on: 30 August 2013, 22:07:25 »
Remove the heatshield from over the exhaust for easier access (same size torx as crank sensor bolt). At the base of dipstick tube feel forward about 50mm (towards front of engine) and you can feel the retaining bolt. Access using a UJ (swivel joint) if you can`t manage with a long 1/4" ext. bar.
If still struggling slip the Aux Belt, unbolt the Power Steering Pump, and move it out of the way
on it's flexible pipes.
Bob G
  • Gloucester
« Reply #9 on: 30 August 2013, 22:17:11 »
Sounds better Rob, will have to see when I get under there Saturday, at least have 2 ideas now, will post results.
« Reply #10 on: 30 August 2013, 22:19:07 »
I removed one from above, 10 mins tops
Bob G
  • Gloucester
« Reply #11 on: 30 August 2013, 22:26:37 »
10 mins, right get on M5 and get up here NOW!!!!!!
Page created in 0.146 seconds with 16 queries.
