vivaro front lower suspension arm removal
Started by mmcg, 03 September 2013, 22:13:31
mmcg
Got the old one off easy enough.Do i put the ball joint on first or the inner bush front or rear.Do i need to follow bush tightening procedure. :-\
chrisgixer
#1
No experience of that vehichle, but looking at pics of Vivanoo arms on the web I'd say bushes in first and no need to tighten wheels loaded.
Both bushes are like the rearward vertical omega ones, which need to go in level and are not tightened wheels loaded.(but the front horizontal ones are, you don't have these)
Once bushes are in with bolts through, I guess you'll have the usual agro of forcing the arm down to get the strut/hub fitted.
mmcg
Thanks its sorted worked out easier than expected. :y
