Author Topic: drivers exhaust manifold gasket  (Read 3816 times)
chappa
  • sunderland
    • omega elite v6
« on: 05 September 2013, 20:52:43 »
hi there is there any one in the north east who would like to do my gasket and will b paid well ive tried but failed and carnt find a step by step its doing my head in now cheers :)
omegod
  • liverpool
    • 2017 Seat Ateca
Re: drivers exhaust manifold gasket
« Reply #1 on: 05 September 2013, 20:58:02 »
Believe it or not that's the easier side , what part of the job are you stuck on?
martin42
« Reply #2 on: 05 September 2013, 20:59:27 »
Drivers side easy ,passenger side,easier to remove head as I found out this evening
chappa
  • sunderland
    • omega elite v6
« Reply #3 on: 05 September 2013, 21:03:17 »
i can only find 2 bolts tried to remove pipes and things but carnt seem to see any more
martin42
« Reply #4 on: 05 September 2013, 21:04:53 »
There's 7 13mm nuts to remove,after you've removed heat shield
symes
  • oxford
    • R reg 940 volvo
« Reply #5 on: 05 September 2013, 21:11:48 »
you got to remove intake pipes and disconnect pipes to egr set up at front of engine--its a pipe just under water/rad hose on drivers side and also remove airbox and water expansion tank---then you can see bolts to heat shield--biggest headache will be water transfer pipe that comes around that side from rear of engine ;) but still is easier than other side :y
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #6 on: 05 September 2013, 21:13:11 »
 ;D ;D ;D ;D
RIP Paul Lovejoy
martin42
« Reply #7 on: 05 September 2013, 21:14:41 »
Well what did you expect from a plumber,lol hammer ,long cold chisel,job done lol
Webby the Bear
  • Northampton
« Reply #8 on: 05 September 2013, 21:17:03 »
believe me mate, your ingenuity saved us tonight! i'd have been buggerd  :'( so all praise to ya mate thanks very much  :y :y :y
might be worth mentioning..... the downpipe to manifold bolts weren't a size!!!!  :o :o :o
RIP Paul Lovejoy
symes
  • oxford
    • R reg 940 volvo
« Reply #9 on: 05 September 2013, 21:57:58 »
yes they are-imperial not metric---well on three that I encountered anyway(now coffee tables-sold on)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #10 on: 06 September 2013, 08:49:26 »
Right. 16mm loose, 5/8" good tight fit. Very strange.
« Reply #11 on: 06 September 2013, 09:03:44 »
They are metric but there a crimped nut  (as is used to stop them coming loose).
The best fit is a hex socket (which is the tool of choice as standard anyway), from memory the ones used for the spark plugs is a perfect fit.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #12 on: 06 September 2013, 10:56:30 »
5/8 tapped on, lots of heat (blue spanner), or if you dont have heat, try to do the nut up, then undo the nut and lots of squirty oil of your choice, undo and do up, takes time but dles work and saves snapping studs.
Hoof'land storeman.
symes
  • oxford
    • R reg 940 volvo
« Reply #13 on: 06 September 2013, 16:56:32 »
yes 5/8 which when I went to school is 14.74mm so if you got 14.74mm metric socket--it will fit
AND you should only ever use hex sockets anyway--less chance of rounding nut/bolt :y :y :y
« Reply #14 on: 07 September 2013, 09:41:12 »
I've always only used metric on the Omega.  I guess if rust has eaten in, it can be any size....
