Author Topic: lost the small hose for coolant bridge  (Read 1588 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 12 September 2013, 07:56:23 »
G84GNB
Reassembling the plumbing. Two pipes emerge from the coolant bridge. The larger, 15mm in diameter, takes the hose to the HBV; the smaller, a brass insert, is 7mm in diameter with a 2mm hole in the end. I cannot find the hose to put onto it. Where does it come from?
terry paget
    • 3 Astras 2 Vectra
Re: lost the small hose for coolant bridge
« Reply #1 on: 12 September 2013, 08:09:09 »
Have found on the bench a long hose that might be the one I am looking for. It might go to the throttle box. Please confirm.
« Reply #2 on: 12 September 2013, 10:04:25 »
Yes, throttle body feed, runs along the top of the 2-4-6 head/cam cover
terry paget
    • 3 Astras 2 Vectra
« Reply #3 on: 12 September 2013, 13:32:10 »
Thanks. That has solved a mystery.
terry paget
    • 3 Astras 2 Vectra
« Reply #4 on: 13 September 2013, 09:06:34 »
I did this job following Haynes, who recommended removing oil pipes. After I had done it, someone said this was unnecessary and unwise. Is that view widely held?
« Reply #5 on: 13 September 2013, 09:11:16 »
Yes, no need to remove the oil cooler pipes.
