Pages: 1 [2] 3  All   Go Down
Author Topic: My V6 dont like less than a quarter tank  (Read 5749 times)
Re: My V6 dont like less than a quarter tank
« Reply #15 on: 23 September 2013, 18:30:37 »
Sounds like crank sensor to me. :-\
    • 530D M Sport, 330i Coupe
« Reply #16 on: 23 September 2013, 18:35:50 »
Agreed
« Reply #17 on: 23 September 2013, 18:40:36 »
I was thinking same, but the engine ECU never gets to see fuel gauge, so not sure how that could correlate to it only happening on low fuel...
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #18 on: 23 September 2013, 19:05:12 »
either coincidence or a fuel filter issue that is now a crank sensor problem.
shaun wilson
  • Banff
    • Omega CD
« Reply #19 on: 23 September 2013, 19:17:52 »
How easy and how much to replace a crank sensor. Im also away to replace fuel pump with a brand new 1. Thanks for info.
« Reply #20 on: 23 September 2013, 20:06:02 »
Right, on my way home from work and while on a single track road I pulled over to let an oncoming car passed, while I was in the passing place the car instantly just cut out. the fuel was sitting just at the top of the red and after turning her over a good few times she started and run as normal.
Any ideas guys.
Cheers
Shaun
Fill it up. Then every time you use 1/4 tank, top it up ::)
Might also prolong the life of the pump...
« Reply #21 on: 23 September 2013, 20:09:56 »
Fill it up. ......
It doesn't do your wallet much good though.
I filled up the Omega yesterday on my way home from work .... £88 and same again tonight in the Merc £100.01  :'( :'( :'(
« Reply #22 on: 23 September 2013, 20:14:38 »
Any ideas guys.
Cheers
Shaun
No petrol car should ever be filled up until the misfires start ::)
Hence, I frequently used to walk down the road with a plastic can in my hand ;D
shaun wilson
  • Banff
    • Omega CD
« Reply #23 on: 23 September 2013, 20:25:56 »
Crank Shaft Sensor, just done the pedal thingy and code 0335 flashed, that's the only code that came up aswell. How much to fix and where is the best place to get a new sensor.
« Reply #24 on: 23 September 2013, 20:29:39 »
Any ideas guys.
Cheers
Shaun
Done that more often than I should have myself :-[
Pretty certain that constantly trying to start it on fumes was what killed the first crank sensor and then the fuel pump :-\
Besides 21-22 litres of fuel still costs £30 regardless of which end of the tank it goes in ::)
« Reply #25 on: 23 September 2013, 20:32:51 »
Crank sensor - ballpark figure £60. Genuine GM only. Follow the guide in maintenance section when fitting the new one. :y
« Reply #26 on: 23 September 2013, 20:34:20 »
Vauxhall only if you want it to last. But isn't that the one code that doesn't mean what it says :-\
shaun wilson
  • Banff
    • Omega CD
« Reply #27 on: 24 September 2013, 18:58:18 »
New sensor on its way, hopefully once I follow the guide and get it fitted then issues should be resolved. Fingers crossed. Can somebody point me in the direction of the fitting guide.  :)
« Reply #29 on: 24 September 2013, 19:01:01 »
Start here ..
http://www.omegaowners.com/forum/index.php?topic=90633.0
end up here ..
http://www.omegaowners.com/forum/index.php?topic=90540.0
Pages: 1 [2] 3  All   Go Up
