Pages: 1 2 3 4 5 [6] 7 8 9   Go Down
Author Topic: Self Leveling HIDs on Elite FL Omega..  (Read 16842 times)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: Self Leveling HIDs on Elite FL Omega..
« Reply #75 on: 19 September 2013, 21:48:17 »
Where exactly is the rear HIDs headlight sensor, Just want to give it the once over make sure it's all there, If all's good with it i'll be done, I've got the lights at a good level now, Can't see anyone's faces or glasses shining now  :y
Thanks for everyone's help and time, Appreciated  :y
« Last Edit: 19 September 2013, 22:00:37 by Mr.OmegaMan »
« Reply #76 on: 19 September 2013, 22:02:08 »
Nearside trailing arm just inboard from the anti roll bar link :y
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #77 on: 26 September 2013, 23:50:24 »
I suppose i really should have a spare set of bulbs, Where is considered the best place to get the HID bulbs VX dealer ?, I've got plenty of Main Beam bulbs.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #78 on: 26 September 2013, 23:53:21 »
HID bulbs probably expensive from VX dealer
other rides
« Reply #79 on: 26 September 2013, 23:57:09 »
<touches wood>   ::)
In 10 years I've never had the need to change a HID 'bulb' ...... I wouldn't worry about a spare  ;)
chrisgixer
« Reply #80 on: 26 September 2013, 23:59:18 »
Hids aren't like conventional headlight bulbs. They last considerably longer, but are very expensive to replace by comparison.
They could also considered dealer fit only due to the warning signs of high voltage all over them. Do tell the Gendarme to bog off with his extortion fine if your going abroad.
I wouldn't worry.
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #81 on: 27 September 2013, 00:51:04 »
Sure I read somewhere even though they last they do degrade somewhat over time Andy  :-\. Probably leave it till next year then when the funds have replenished   ;D
chrisgixer
« Reply #82 on: 27 September 2013, 01:17:31 »
Jimbob might advise on a supplier
« Reply #83 on: 27 September 2013, 08:35:09 »
As HID bulbs are (officially) only to be changed by trained personnel, you can tell the French to bugger off. Same as if you drive an Audi, as all bulbs are dealer change only.
They tend not to just fail, you get plenty of warning.
They do degrade over time, but the 15yr old ones on the Bullet, having done 210k, are still OK.
« Reply #84 on: 27 September 2013, 11:43:15 »
Have only needed to change one through failure, until recently, 95% of my driving was done at night :y
As TB says, you get plenty of notice, they gradually develop a pink tinge, eventually they don't fire, mine actually went bang, shattering the bulb, but it had been pink for about three months ::)
Halfords stock some, but they're more expensive than Vauxhall iirc.
The bulbs themselves are a piece of cake to change, but you need to take the headlight out, (for ease of access) and if you treat as you would an airbag, then you shouldn't fry yourself :y
« Reply #85 on: 27 September 2013, 12:03:56 »
The bulbs themselves are a piece of cake to change, but you need to take the headlight out,  .....
which on the better looking cars involves removing/dropping the front bumper  ;) ;)
chrisgixer
« Reply #86 on: 27 September 2013, 12:09:32 »
Er... I don't think it does mr P.
Some fiddling around with the the under head light trim, some 1/4" drive extensions and a bit of tape to hold the bolt on for refitting, but I've never removed a bumper, on the superior face lift or the Bart Simpson lookalike pre face lift, for head light reasons.
« Reply #87 on: 27 September 2013, 12:16:01 »
IIRC the headlight won't come out with the bumper on because the headlight washer fouls it.  ;)
chrisgixer
« Reply #88 on: 27 September 2013, 12:21:26 »
Mmmnope. Hence the trim piece underneath. Headlight sits above the bumper by an inch or so. No?
chrisgixer
« Reply #89 on: 27 September 2013, 12:23:19 »
Only doubt I have is the mini face lift washers. I've not owned a car with those.
But I'd of thought the light would clear those too, similar height to superior face lift ones?
Pages: 1 2 3 4 5 [6] 7 8 9   Go Up
Page created in 0.039 seconds with 16 queries.
