I know that a lot of OOFer's hate BMW........but?
Started by Field Marshal Dr. Opti, 16 September 2013, 14:34:23
.....what is the going rate for a 53 plate 330CI manual from a garage
80,000 miles.......service history.
Cambelt problems?
I've just returned from a test drive and it felt as tight as a drum. :y
henryd
Quote from: Mr. Opti on 16 September 2013, 14:34:23
Cambelt problems?
Nice motor,if I had all your money Opti I'd buy it ;)
other rides
Quote from: henryd on 16 September 2013, 14:56:35
Cambelt problems?
Not for myself, Henry.  Personally I think it's a hairdressers car.
However, Mrs Opti wants yet another car to replace her short-lived RX8. :-\ :-\
It will come with a new MOT, a full sevice stamped in the book , and 6 months tax.
He won't budge on £4495 though. :-\
My bro had a 330 from that vintage. Bloody expensive to run (oil was about £50 a litre, tyres were £300 a pop, and not repairable (and he had 2 punctures in 2 weeks after visiting me ;D)), but it was awfully quick, and a hoot to drive when it wasn't snowing (the TC prevented it moving in snow).
His was an Alpina one though, with (proven) better top end than an M3
Cambelt problems?
as the famous word/sentence (whatever)  the car is as good as its owner(s) .. I have seen bimmers with galactic miles which are tip top.. and seen some with few miles in crap condition..  so it depends.. one warning , some of them have faulty vanos units and its expensive to repair..  also there are many other things that can go wrong.. so its a must that you see have to see its service papers..  also some of them crack from the rear axel connection points.. if you ask my opinion bring it to a bmw specialist  and lift up and examine below the car.. also connect it to computer and check other things.. will tell many thing and pay for check..
I have seen examples at 150K miles that you put a coin on engine at idle and the coin stays as it is :o
one  more, if you will pay that sum, E46 m3 also is worth checking as maintenance costs not very different..  but powerwise they are very very different.. only problem is clean examples are rare..  so get ready to empty the bank ;D but be warned once you drive them (m3) you will be addicted  ;D ;D
ps: remember you live only once and no one brings even a penny to other side ;D :y   (buy fot yourself)
Quote from: cem on 16 September 2013, 18:27:34
I have a perfectly good 210k miles 3.0l Omega that you can do that on ;)
Quote from: TheBoy on 16 September 2013, 18:32:11
mine also  :) :y
Mr.OmegaMan
Someone has already done this with an Omega V6 don't know if its 2.5/3.0 though..
http://www.youtube.com/watch?v=LTz9jd5gxFE
chrisgixer
Cambelt problems?
So its got about 40k left in it before the suspension needs doing. Cam cover seals and missfires are slightly better than omega but not much, single coil per plug and very expensive.
Spend the dosh in your omega and save money.
Mr.OmegaMan
Quote from: chrisgixer on 16 September 2013, 18:48:23
Cambelt problems?
It's for the Mrs i think  ;)
Quote from: Mr.OmegaMan on 16 September 2013, 18:53:37
Cambelt problems?
I always buy for mrs than use for me ;D
Cambelt problems?
Yes....I wouldn't be seen dead in it.......( with the exception of the test drive... ::) ::))
Quote from: Mr. Opti on 16 September 2013, 18:56:13
Cambelt problems?
Yes....I wouldn't be seen dead in it.......( with the exception of the test drive... ::) ::) )
ok.. I know whats in your mind.. v12..
here you go ;) :y
http://www.carandclassic.co.uk/car/C408453
Mrs Opti's so lucky to have a wealthy and generous husband!  :P  Even if he is a minger! ;D
