Author Topic: 2.2 dti fault code reading  (Read 6164 times)
Y26SE
  • Spalding
    • 2002 Omega 2.2 DTI saloon
« on: 16 September 2013, 16:26:12 »
Hi all. ive now changed from a petrol to a diesel omega and i come with a couple of fault codes if i may
51 plate 2.2 dti with the following codes
P1635 – Glow Device Circuit General Error
P0400 Critical malfunction 2 refer to checking procedure
P1590 – Engine Running Signal High Input not present.
car runs like a bag of poo but once warmed up its seems ok.
any help in where best to look first.
Thanks
Mark
What is this FUEL ECONOMY you speak of, it is alien to me.
Not now i have a dti: Omega ownership without the petrol station bite. JUST GARAGES INSTEAD
Re: 2.2 dti fault code reading
« Reply #1 on: 16 September 2013, 16:31:02 »
What the relative resistance of all  your glow plugs. I forget now what the codes were, but both on the Astra G TD of mine & that of my s-in-law's Astra H a code referring to glow plugs lead to me a failed glow plug.
Check to see if the resistance of all the glow plugs is more or less the same .... the one that isn't is the duff one!  :y :y
no idea on the other codes  ::) ::)
Y26SE
  • Spalding
« Reply #2 on: 16 September 2013, 16:50:23 »
Ah good ill have em out and stick power to them and see who glows thanks. ;D
« Reply #3 on: 16 September 2013, 17:09:59 »
No, just stick a multimeter on resistance from the contact on top of them to earth (or for Mark zero volts - the block)  ;) ;) As said, you're looking for an odd man out reading of the four  :y
« Reply #4 on: 16 September 2013, 17:11:07 »
Be aware that sometimes these plugs tend to seize in the head :(
I'd also fully clean out the inlet system, to allow all the inlet sensors to work
P6UL K
  • Dartford, Kent
    • Vauxhall Omega 3.0 Elite
« Reply #5 on: 16 September 2013, 17:18:40 »
Is there a correct procedure for this?
Y26SE
  • Spalding
« Reply #6 on: 16 September 2013, 18:07:54 »
Ill get my meter out  :)
Any other hints on the other codes. I tried clicking on the malfunction 2
 but I got no further details and the high signal missing?
Y26SE
  • Spalding
« Reply #7 on: 16 September 2013, 19:18:30 »
confirmed GP no4 open circuit. cheers for that one people. ill get one from the factors tomorrow
Y26SE
  • Spalding
« Reply #8 on: 16 September 2013, 19:19:58 »
An additional fault has just popped up aswell now. on the mid screen. low beam vsr fluid or something like that
« Reply #9 on: 16 September 2013, 19:21:34 »
HID level sensor is upset. Sometimes it's as simple as the front sensor's arm has popped off
Y26SE
  • Spalding
« Reply #10 on: 16 September 2013, 19:31:21 »
ill have a look tomorrow at that aswell  ::)
Y26SE
  • Spalding
« Reply #11 on: 16 September 2013, 19:44:11 »
Thanks
Mark
is the P1590 code a battery or alternator voltage issue? and the critical malfunction 2 is related to this
andymp
  • Wakefield, UK
    • 2003 Omega CD 2.2 dti Est
« Reply #12 on: 17 September 2013, 07:26:34 »
P0400 means maf sensor reading out of operable limits. Usually caused by an egr malfunction. Check vacuum rubbers.
Artificial intelligence is no match for natural stupidity...
andymp
  • Wakefield, UK
« Reply #13 on: 17 September 2013, 07:29:42 »
P1590... check your alternator output voltage.
Y26SE
  • Spalding
« Reply #14 on: 17 September 2013, 09:45:03 »
Just a quick question on this arm. Is it easy to see the arm on the headlight or am I looking at the fabled plastic adjusters that go
