Author Topic: Hid level sensor missing something  (Read 3070 times)
Y26SE
  • Spalding
    • 2002 Omega 2.2 DTI saloon
« on: 19 September 2013, 13:57:19 »
Hi all. My fld vision fault on my hid lights could be the fact i think something is missing. the rod and what ever it connects to on the wishbone is missing i think. could someone confirm what Im meant to have
it looks like im missing some kit
What is this FUEL ECONOMY you speak of, it is alien to me.
Not now i have a dti: Omega ownership without the petrol station bite. JUST GARAGES INSTEAD
Re: Hid level sensor missing something
« Reply #1 on: 19 September 2013, 14:58:42 »
Difficult to tell from the pics, but there should be an arm on the back of the sensor, which is connected by a rod to a bracket bolted to the upper face of the wishbone :-\
At a guess I would suggest that the wishbones have been replaced with cheapy ones without the threaded hole for the bracket, and whoever fitted them simply broke the rod and arm off rather than improvise ::)
If you can, a pic from the front, or straight along the top of the rear edge of the wishbone should confirm (or not) my suspicions :y
« Reply #2 on: 19 September 2013, 15:00:47 »
Where's RobG? I'm sure he has a picture!  ::) ::)
Y26SE
  • Spalding
« Reply #3 on: 19 September 2013, 15:33:47 »
oooh a picture of how its meant to look would be ideal.
« Reply #4 on: 19 September 2013, 15:56:05 »
Does this help ??
« Reply #5 on: 19 September 2013, 15:58:42 »
Does this help ?? ....
I knew there was  :y
If only you'd posted before I went out in the wet with my camera   ::)  ::)  ::)
« Reply #6 on: 19 September 2013, 16:00:21 »
I knew there was  :y
Not my pictures .. but google advanced search works .. :)
I think the photo is Broocies ... :)
« Reply #7 on: 19 September 2013, 16:01:40 »
so it seems  ;D ;D
« Reply #8 on: 19 September 2013, 16:38:59 »
Looking at what isn't present between the two pics, I would suggest my hunch was correct ::)
« Reply #9 on: 19 September 2013, 16:44:42 »
Agreed.  :y
Why would anyone think that it's OK to remove an item rather than refit it  ???
« Reply #10 on: 19 September 2013, 17:16:30 »
FVSH ::)
Stupidity always seems like a really good idea at the time :-X
Y26SE
  • Spalding
« Reply #11 on: 19 September 2013, 18:36:02 »
Does this help ??
Brilliant thank you that paints a thousand words for me. no i know what to expect
Y26SE
  • Spalding
« Reply #12 on: 19 September 2013, 18:38:45 »
FVSH ::)
Im not joking either. your right and the last service i confirmed was twells of Billinghay here in lincolnshire. a full vauxhall dealership serviced 4000 miles before i bought it. i hope this failed after the service !
« Reply #13 on: 19 September 2013, 18:42:46 »
From that pic you need
4, 6, 7 and 13 :y but try the breakers here first, as the sensors are pricey new...
As that IPC shows, front and rear sensors are the same, as are the rods, but you'll need the bracket as that is clearly missing from the wishbone :y
« Reply #14 on: 19 September 2013, 18:44:35 »
..... and different. I remember Lizzie Z posting a picture of the sensor along with the modified section of loom due to different plug/socket
