Author Topic: Diesel heater  (Read 1893 times)
Y26SE
  • Spalding
    • 2002 Omega 2.2 DTI saloon
Diesel heater
« on: 19 September 2013, 14:04:07 »
Hi all, on my mooch around the car i think i found a diesel heater in the front arch. could people confirm if this is the case as ive found it with the connectors bagged up but would be nice to see if i can get it going.
Thanks in advance
What is this FUEL ECONOMY you speak of, it is alien to me.
Not now i have a dti: Omega ownership without the petrol station bite. JUST GARAGES INSTEAD
    • 530D M Sport, 330i Coupe
Re: Diesel heater
« Reply #1 on: 19 September 2013, 18:52:03 »
Yep, that's the heater.
Y26SE
  • Spalding
Re: Diesel heater
« Reply #2 on: 19 September 2013, 19:35:47 »
How does it or when does it work if it was all pugged in?
fergy
  • Hereford
  • 2001 CDX 2.2dti Estate
Re: Diesel heater
« Reply #3 on: 22 September 2013, 13:19:44 »
Been a while now with nor replies, so here goes!
 It is a coolant heater made by Erberspatcher. Designed to enable rapid warm up of engine and thus air con in cold weather. Fitted to the Dti only in the Omega range it generally works well until the salty gunge from the road  builds up under the GM made mounting bracket. Then the aluminium heat exchanger rots through from the outside and deposits your engine coolant next to the off side front wheel
The heater has no user controls it is activated by a thermostat/ coolant temperature sensor. As yours has been disconnected I imagine it has suffered like all the rest. With mine I took considerable trouble in trying to find a replacement heat exchanger but to no avail. I was informed by Erberspatcher dealers that spares are only available from GM .
 To test it you would need to check that the the in and out  water hoses are connected and plug in the currently bagged up loom, not forgetting to confirm the diesel supply is intact  If the person who disconnected it did a fair job I would hope that they removed the fuse from under the dash. from memory No 14 of 15. As they did not remove the heater it looks like a minimal disconnect job to me.
One other requirement is cold weather, again from memory a figure of below 5 C comes to mind as being specified, but mine kicked in about -2C.  I'm pretty sure that I found out the connector pin out by repeated internet searching, but someone more clever that I should be able to tell you how to fool it into starting up.
andymp
  • Wakefield, UK
    • 2003 Omega CD 2.2 dti Est
Re: Diesel heater
« Reply #4 on: 22 September 2013, 14:26:20 »
An Eberspacher D3WZ auxillary water heater. Excellent piece of kit when it works. Smoky when it doesn't...
Artificial intelligence is no match for natural stupidity...
andymp
  • Wakefield, UK
Re: Diesel heater
« Reply #5 on: 22 September 2013, 14:30:49 »
Diagrams and manuals are easily obtainable on the net. Search as well for ford galaxy or vw sharan auxillary heater.
Page created in 0.027 seconds with 16 queries.
