Author Topic: Please may I re-use my coolant brige washers?  (Read 1904 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 21 September 2013, 14:26:06 »
X84GNB 2.5 petrol V6 manual estate
I have changed the RH exhaust manifold, reassembled, and suffered coolant leak due to missing coolant transfer pipe O ring. Dismantled, replaced O ring and glued it in place, reassembled; refilled with new coolant, started engine, observed coolant flood at back of engine. Stripped it down again, discovered one of the coolant bridge bottom washers was absent.
I have four spare washers from my earlier assembly. They have been inserted once, torqued up, then replaced after earlier leak. I know I should buy new washers, but I shall not get any before Tuesday. Would I be daft to reuse the spares I have?
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: Please may I re-use my coolant brige washers?
« Reply #1 on: 21 September 2013, 14:59:14 »
i would think you may get away with them tbh. just my opinion of course.  :)
  • Auckland
    • Mazda MPV
« Reply #2 on: 21 September 2013, 15:14:23 »
I cannot remember whether they are solid metal (aluminium or copper), crushable metal, or metal with a ring of rubber bonded to the inside :-\
terry paget
    • 3 Astras 2 Vectra
« Reply #3 on: 21 September 2013, 15:37:19 »
They are a metal ring with a rubber ring bonded in the centre.
chrisgixer
« Reply #4 on: 21 September 2013, 16:22:31 »
If the rubber inner seals look un damged, then I'd refit them. If torn or nipped in any way, binem.
...rightly or wrongly. It is just the rubber that seals these I thought, they're not a crush washer as such...?
The Red Baron
« Reply #5 on: 21 September 2013, 16:33:02 »
as above. they are metal with rubber ring.  :y
  • Auckland
    • Mazda MPV
« Reply #6 on: 21 September 2013, 16:44:50 »
As Chris said - if the rubber is undamaged they are good to re-use. What you may find is that the rubber has gone hard in which case it is your call whether you think it is still elastic enough to form a seal.....
« Reply #7 on: 21 September 2013, 22:13:06 »
Personally I always fit new - but in an "emergency" I guess its your choice whether to rebuild with a used seal.  At best it will work out ok, at worst you'll end up doing the job again to fit new seals!! For what they cost, imo it's a no brainer ;)
terry paget
    • 3 Astras 2 Vectra
« Reply #8 on: 22 September 2013, 13:58:54 »
I refitted the used seals last night. This morning filled with antifreeze and started up - no leaks!
I appreciated that for £10 buying new was the wise course, but I was impatient.
Thanks to all for advice.
« Reply #9 on: 22 September 2013, 18:59:55 »
Hope they hold up ok for you ;)
« Reply #10 on: 22 September 2013, 19:05:59 »
At least not that hard to get to if they do fail, so I see it as no harm done TBH.
If they looked oviously damaged, I'd just replace them as a matter of course, even if they appear to be water tight now.
Page created in 0.031 seconds with 20 queries.
