306 internal fan not working?
Started by Dan282, 22 September 2013, 16:32:40
Dan282
As well as the omega I have this little 306 xsi which I'm going to sell
Only problem I have is that the internal fan doesn't work. When at speed you can feel the heat coming through the vents so I know the temperature control is ok.
Any ideas or experience with these anyone.
Dan :)
henryd
Could well be the motor itself,easily accessed from below glovebox,resistor pack also fails but normally you get full speed but not the intermediates when that happens :y
other rides
Dan282
Cheers mate. Will have a look at that tomorrow :y
henryd
Fan motor has red and black wires going into unit,red is ignition on live and switching is done via the black wire,if you have live feed and earth the black wire to ground the fan should run at full tilt :y,if yours has the variable speed fan rather than 3 or 4 set speeds then the resistor is in the motor casing
other rides
