windscreen washer bottle
Started by MadMark73, 23 September 2013, 19:42:57
MadMark73
Could a very kind admin please move this to the correct section.
Does anyone have a non leaking washer bottle to fit a 98 elite estate.( i think its a front bumper off job).
If anyone has how much posted to Taunton, Somerset.
Many thanks, Mark.
Got one here from a facelift elite saloon. No idea if its the same or not tbh. :-\
MadMark73
It's for an s reg(98) 3.0 elite estate.
Deleted a 'dangle berries' answer from myself, and some from Andy B (at his request).
On prefacelifts, 2 sizes IIRC, Elite should be the 6.3l.  Same across range I believe?
Except some dont have sensor hole...
I can take a pic tomorrow and post it so the op can compare if it helps. I really have no idea if they are the same,although 6.3 L sounds familiar.
Actually,iirc the pre/ mini fl tanks have a longer filler neck. I also have a vague recollection that the f/l version can be extended to do the same thing ?
The tanks for those cars with HID washer pumps are bigger.  :y
Quote from: Albitz on 23 September 2013, 20:30:49
It's a mod that some do so that the yellow filler car can't be seen though a facelift grille ... it extends to the slam panel.
Quotethe pre/ mini fl tanks have a longer filler neck
Correct
Quotethe f/l version can be extended to do the same thing
Correct
Ah the return of the oracle. :) :)
So, will a f/l saloon tank be ok for a m/fl estate ?
Quote from: Albitz on 23 September 2013, 20:53:42
depends on what I said above .....  ::) HID washers & level sensor for MID/TID/GID/etc  ::)
Elite will have washers presumably and if the sensor isn't needed it can be left disconnected ?
I would imagine its  question of whether it will physically fit and do the required job ok.
Quote from: Albitz on 23 September 2013, 20:59:21
Yes dear Albs  ;)  ;)
