oh Dear
Started by bago, 27 September 2013, 17:50:32
bago
well did a oil change yesterday as per maintence section all fine did 50 miles it had a check all fine nol leaks or drips.
went town today  and now leaking oil. looks like from the oil filter cap so will end up doing another oil change . any comments  to make sure it does not happen again can you by a new oh ring for the cap?
Filter should have come with a new one :-\
Either way, don't be tempted to tighten it even as a stop gap :y
Lightly oil new o-ring prior to fitting ;)
Have you fitted the O ringin the correct groove? And as above oil O ring.
bago
yep fitted in the correct groove its notthe canister type its the paper filter with a screw on cap
You don't need to drain oil to fix that :)
Quote from: bago on 27 September 2013, 17:57:46
I know .......... the spin on has a seal embedded into the filter - no O ring involved.  ;) ;) ;)
Check the filter is tight. If OK the seal might have been nicked during tightening. If it's damaged you might be able to re-use the one off the old filter. ;)
kevinp58
Quote from: bago on 27 September 2013, 17:50:32
Yup fit the correct type of filter  :y :y the spin on type  ;D ;D
2nd time I changed mine I greased the O-ring because I really didn't want the cap to seize in place.
After 2 days it started leaking  >:( so I took the cap off, cleaned away the grease and put the old seal back on with a smear of oil this time. That fixed it :y
Quote from: kevinp58 on 27 September 2013, 20:23:06
And with all the R & D available to GM they still can't design an oil filter.
Just refit as it was intended & it'll be right!
