Dash illumination ? MOT
Started by omega3000, 27 September 2013, 21:15:25
Anyone know if dash illumination has to work for the mot  :-\
tidla
On trucks yes, so i would imagine the same applies?
Due to the set up of 'my' MOT station, I'd doubt Mr MOT Tester would be able to tell ...... he'd have to close the roller shutters & kill the main lights to notice.
I'd say no ....... but what do I know  ::)
tidla
Quote from: Andy B on 27 September 2013, 21:23:37
A shade less than tunnie. ;D
Crazycarzowner
Apparently from March 2012 :-
The main changes
Electronic parking brake
Electronic parking brake controls are now included and must be present and not inappropriately repaired or modified - repair obviously likely to adversely affect the roadworthiness of the vehicle or modification that has seriously weakened the component.
(The 'inappropriately repaired or modified' check is to be applied to a wide range of systems and components throughout the vehicle.)
The car will fail if an Electronic Parking Brake warning lamp is illuminated to indicate a malfunction.
Electronic Stability Control
Checks of antilock brakes will be extended to include Electronic Stability Control if fitted.  The tester will check for the presence and correct operation of the ESC malfunction warning light together with looking for obviously missing, excessively damaged or inappropriately repaired or modified components and electrical wiring, as well as an ESC switch missing, insecure or faulty.
Warning lights
As well as electronic parking brake and electronic stability control warning lights (where fitted) the MOT test will also include checks for the correct function of the following, where fitted;
    Headlight main beam warning light
    Electronic power steering warning light
    Brake fluid level warning light
    Seat belt pre-tensioner warning light
Quote from: Jasonm on 27 September 2013, 21:52:56
The main changes
Warning lights
But nothing there about dashboard illumination ::)
Quote from: tidla on 27 September 2013, 21:51:04
:D :D......... :-X
Gee! Thanks .................  :( :(  ;D ;D
tidla
b4ndit
Dash illumination not required for mot only warning lamps must work :y
Thanks for all the info chaps  :) :) :) Got to replace a few bulbs in the dash but im up to my neck in other jobs at the minute especially with the angle grinder on suspension items  ;)
