Part Numbers ?
Started by omega3000, 28 September 2013, 16:37:38
So many different part numbers for anti roll bar bushes and dont seem to be able to find the correct size for my vectra  :( Ive been to vauxhall and they had one that i compared but it still looks wrong "too small" ?
Measurement comes up as 20mm roll bar . Apparently the biggest roll bar bush is 18 1/2 .
So are these roll bar bushes ultra compressible as there is a big gap once the bush is on the roll bar  :-\
Seems i wasn't trying hard enough  :-[ The trick seems to be to wedge the plate over under the back bolt then wind down the front bolt so it pulls together  ::) Not easy but at least problem solved  ;D
