Welding, and remember my garage electrics?
Started by chrisgixer, 28 September 2013, 21:17:59
Shackeng
Quote from: Kevin Wood on 03 October 2013, 21:23:43
Quote from: chrisgixer on 03 October 2013, 21:11:07
What I want, is somebody else to look at that knows wtf their doing ;D
AndyRoid has kindly offered to pop over, when he's feeling well enough. Bless him :-[
I'd take him up on that, if I were you, but I'd be happy to take a look if you want your mind put at rest in the meantime, once I've finished my week of flying round Scotland trying to avoid the sticky-up bits of land.
Quote from: chrisgixer on 03 October 2013, 21:13:48
She's hidden them ;D
Offs! ::)
I can't get that dial to make an ounce of difference tbh. Experimenting with holding the torch at various lengths away from the job seems to have more affect. :-\
Hmm. I suspect the speed controller is fubar. Should be an easy fix, though.
Agreed, as it did control speed when I had it. :y
chrisgixer
Is there any point me looking inside the case at the dial?
Shackeng
Quote from: chrisgixer on 04 October 2013, 16:32:31
It may be fairly simple to test with a multimeter Chris. :y
chrisgixer
Quote from: Shackeng on 04 October 2013, 23:10:10
So no then, given my lack of experience with electwickth. ;D
AndyRoid
Quote from: chrisgixer on 03 October 2013, 21:40:39
He's pencilled me in for my next off shift, if suitable. :y
You're still on Chris, probably from next Fri/Sat onwards based on how I react to Tuesday's upcoming chemo  :y
chrisgixer
Quote from: AndyRoid on 05 October 2013, 09:47:59
Best of luck with treatment.
Look forward to seeing you when your feeling better. :y
chrisgixer
2woody was down today. He confirmed the speed dial for the wire feed inactive. Stuck on a fast setting.
Gas setting was too low I think. :-\ regulator adjusted. Quick blast and it did lay a nice thick heavy weld. He used a SSSSS (best I can do on a keyboard) sort of figure of 8 type pattern with the torch.  Big chunky weld on that test piece I used, and LOADS more heat has gone through the metal. It's all gone blue. :y
Anyway, its all set up. All I have to do is hit the button for engine mounts. :)
He'll be back down again in a couple of months to sort out the mess then. ;D
Thanks 2woody. :y
chrisgixer
Quote from: ex taxi al on 19 November 2013, 22:54:43
Busy day then and not even friday :o
Yep, Friday tomorrow.
Although do you mean 2 woody? I think he had a longer day than I did tbh. :-\
Quote from: chrisgixer on 19 November 2013, 23:00:48
That's the price he pays for living in the back of beyond.. ;D
Now all you need is to get that speed controller fixed.. and that engine in that car ;)
Gaffers
Quote from: chrisgixer on 19 November 2013, 22:24:10
That would explain my issues while using it (and the burn marks from the hot metal balls which managed to find their way inside my gloves :-[)
I just thought it was me  :-[
AndyRoid
#116
Quote from: chrisgixer on 03 October 2013, 20:36:25
Power. Need more POWEEEEEER ;D
A new CU and a dedicated feed to the garage will sort that.
Quote from: TheBoy on 03 October 2013, 21:02:31
Not quite that straightforward, as we don't know the cable size from CU to garage, or if its a ring or spur.
The feed is 1.5mm² T&E which has been spurred off of one of the ring circuits  :o
CaptainZok
Quote from: AndyRoid on 20 November 2013, 10:35:03
Does it glow when he arcs up? ;D
TuBy's new whipping boy.
chrisgixer
Quote from: CaptainZok on 20 November 2013, 13:29:06
No, because he uses an extension lead plugged into the kitchen. ::)
CaptainZok
Quote from: chrisgixer on 20 November 2013, 13:33:19
Probably for the best. We don't want a rerun of TuBys garage incident do we.
