Author Topic: Which handbrake side is the longer?  (Read 2026 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 28 September 2013, 21:46:54 »
OE03EWW 3.2 petrol manual saloon
I am changing the handbrake cable. I have changed them before. I read in the maintenance guide that the cable lengths are different. I have already removed the old cable, assuming both cables were the same length. Which side is the longer?
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: Which handbrake side is the longer?
« Reply #1 on: 28 September 2013, 21:54:36 »
one cable that splits into two. didnt think there was any difference on either side tbh.
« Reply #2 on: 28 September 2013, 22:39:06 »
Fairly sure both sides are same length
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #3 on: 28 September 2013, 23:17:51 »
Me too  :-\
Only a job I've done once - MFL 2.5 - but I can't see them being any different across the range  ???
« Reply #4 on: 29 September 2013, 03:12:58 »
IIRC the off side one is a touch shorter, as the nearside one has to clear the exhaust :y
dbdb
  • west london
  • Tramlining,Trade Club,WIM,my time racing,Linux etc
    • f/l elite 2.6 V6 manual
« Reply #5 on: 29 September 2013, 15:04:02 »
On EPC they look identical but both come as one kit - part number 90374841
« Last Edit: 29 September 2013, 15:06:08 by dbdb »
« Reply #6 on: 29 September 2013, 15:59:06 »
The cable assembly is effectively a single unit consisting of two cables connected by a bar,sandhould be identical accross the range :y
Changed mine six months ago and vaguely recall the routing not being symmetrical, hence one side being a touch longer...
Guess Terry has found one side longer, hence the question :-\
« Last Edit: 29 September 2013, 16:00:57 by ex taxi al »
terry paget
    • 3 Astras 2 Vectra
« Reply #7 on: 29 September 2013, 16:38:21 »
No, I have changed two or three in  my time, and never thought the lengths were different. Yesterday I read the maintenance guide after removing the old cable and before installing the new cable, and found to my alarm that I had to be careful to install the two cables the right way round. I measured the new (aftermarket) cables, they seemed to be the same length, so I did not worry about it. Cable is now installed, and handbrake action much improved. The old one had got very stiff, so much so that the poor return springs could barely cope. I found it quite a tricky job, even with a pit. It must be awful crawling under the car all the while.
« Reply #8 on: 29 September 2013, 16:43:15 »
In no real rush to do it again ::) but it was easier to do on the ground than a clutch change ;D
Glad sorted :y
Page created in 0.025 seconds with 16 queries.
