Big thanks to Martin42...
Started by Webby the Bear, 30 September 2013, 10:42:26
Webby the Bear
aka magic tree. aka green cabby. aka mad mech. lol
got the heads on. torquing with the degree wheel on the pass. side was a b*tch. but not as much as those two stuck lifters! martin has unbelievable patience. and a chisel and hammer and two hours later they were out.
massive thanks mate :)
got some metal shavings around the valve but this was xcompletely unavoidable. cleaned up as best i could.
hopefully this wont hinder too much when it starts up.
cam shafts....
am i right in thinking i fit the shaft. do up the bearing caps (inc green snot on end one). fit the cam seal. fit the rear timing cover. then fit sprockets???
RIP Paul Lovejoy
henryd
Quote from: Webby the Bear on 30 September 2013, 10:42:26
cam shafts....
Yep :y
other rides
Webby the Bear
Thanks Henry.
should i lube up the cam seal with oil? and do i put oil on the cam shafts and between the bearing caps and the head? :)
RIP Paul Lovejoy
A light lube of the cam seal first, I alway fit the cam seal to the cam first rather than knocking it in after fitting of the bearing caps.
Make sure you get the right cams in the right places!
Webby the Bear
Quote from: Fuse18 on 30 September 2013, 13:45:39
lol thanks mark. yeah ive got that process nailed. making sure the number on the sprocket hole lines up with the notch on the camshaft...then bring it round and lock in place.... thwen once all in crank to TDC from its current 60 degree BTDC mark :):):)
so i'm to use the green snot around the perimiter of where the cam seal lives also... as well as at the front of the first cam cap? :)
RIP Paul Lovejoy
Whats all this green snot talk  :D ;D Well done martin . Hope she fires up and keeps running for good this time steve , seems ages since that dreadful day  :(
Webby the Bear
Quote from: Emd on 30 September 2013, 15:15:37
exactly 30 days today :(
never mind, im over that now. just concentrating on getting this sucker back together.
if i balls it up again ill just have to buy another one  ::)
RIP Paul Lovejoy
Sure it will be fine  :y Wasnt your fault anyway , faulty part  :) 30 days !!! Bloody norra how time flies  :(
martin42
No problems mate,thanks for the beer tokens  :y
Webby the Bear
Quote from: The Mad mechanic on 30 September 2013, 20:22:53
You bloody deserve them son. Seriously I've never seen patience and perseverance like it. I was ready to say ''fek it, ill just get a new Omega''  ;D
RIP Paul Lovejoy
