Just a project idea for the future
Started by dawidski, 04 October 2013, 03:37:53
dawidski
Is the bmw straight 6 lump 2.5td (the one fitted to omegas) similar in build as the petrol version if so would it be possible to fit an m3 or 328i engine in the omega using the diesel engine mounts?  :D This issue gives me sleepless nights. I would love to fit a 320hp motor in my omega.  :y
I dream of an LC
It would be easier to fit Lotus Carlton running gear,although finding it might be the hardest part.
Has anyone ever put a straight 6 in an omega ? Cant recall seeing one  :-\
henryd
Quote from: Emd on 04 October 2013, 11:28:34
Vauxhall put the straight six TD lump in there so every reason to think that another straight six petrol or diesel would fit :y
other rides
As above, every 2.5 TD is a straight 6  :y
Also seen a Lotus 3.6 S6 in an Omega, which went in ok.
Think a 328i engine would be pointless, as would 3.0 straight 6, not much gain?
dawidski
Quote from: tunnie on 04 October 2013, 12:21:56
The Lotus 3.6 is hard to find and would be expensive to run also its turbo so I'm guessing they are not cheap to replace.
M3 3.2 (e36 version) 320hp or (e46) 340hp I think is a good enough option. The 3.0 (in the e46) has about 245hp and I think with a little tune would run about 260, me thinks anyway  :(  So it does seem worth it. I know the omega v6 can get some serious power, but I'm not sure about reliability.
Unless you guys can tell me if you can swap in like a 3 liter diesel from the 5 series ?  :P
I dream of an LC
If I can squeeze a 3.8S Jag lump and gearbox into a 105E Ford Anglia, then anythings possible with engine swaps ;)  Having said that some transplants are easier than others, and other parts usually need upgrading like suspension, braking and drivetrain etc ;)
dawidski
Tbh if I was doing a swap I would buy a whole car so I could get all the bits needed  :y
I dream of an LC
Apart from no cuts to the hands when working on a V6  ;D ;) I guess the Skyline would be a better transplant option  :y
martin42
Hasnt there been a toyota supra engine been dropped into an omega??
Keith ABS
  Was one dropped into a Carlton GSI a few years back
Keith B
Quote from: The Mad mechanic on 04 October 2013, 19:29:39
Yep was on OOFer from Thailand IIRC ;)
