Any Vectra B specialists?
Started by PAULCDX, 06 October 2013, 18:28:24
It won't be the linkage, if it was then other gears would affected to.
Its most likely clutch related, first port of call would be a fluid change and bled from the bottom up.
grain.ben
Quote from: Fuse18 on 06 October 2013, 19:20:31
Don't agree there mate, if it is the same problem I had, it was hard putting it into 1st, then from 1st to 2nd, 3rd 4th 5th and reverse were all fine, new linkage sorted mine, I would replace the linkage first, if the problem is still there, start looking at the clutch and gb fluid level
Arguably, a fluid change is cheaper, easier, and quicker than swapping the cable and adjusting it :-\
VX usually have offers on things like brake fluid changes :y my Mot place charges £35 for a fluid change...
Quote from: Tall Paul on 06 October 2013, 19:15:20
I also have another issue  >:(
Car with the spanner light comes on all the time, previous owner told me it was code P1555 which points to the throttle body I think?
I'm hoping it just needs a good clean out  :-\
Take throttle body off and clean it , probably all gummed up . Other thing mite be maf sensor .
PAULCDX
Thanks for all the replies,
I've certainly got some food for thought and places to start etc.  :y
May shout up for help though  :D  ::)
Quote from: grain.ben on 06 October 2013, 19:27:27
Totally different setup to Corsa, it won't be gear linkage and as you have just confirmed linkage affects more than than one gear
grain.ben
