Any Vectra B specialists?
Started by PAULCDX, 06 October 2013, 18:28:24
PAULCDX
Hi,
Noticeably from cold I really struggle to select first gear, I really have to force it into gear even though the clutch is completely down etc. 2nd - 5th don't seem to bad at all?
Once warmed up and used more it doesn't seem as bad. Is this a gearbox oil problem or linkage / selector etc?
Car only has 36k genuine miles so I'm hoping it's not an actual gearbox fault :(
If it's an oil issue, can anybody recommend a brand / type / grade etc  :y
Thanks in advance,
Paul  ;)
grain.ben
I had this problem on my corsa c and it turned out to be the gear linkage had worn, new one fitted, no more problems.
But, could be a different thing altogether on a Veccy  :-\
Not had that problem on my Vectra B but does sound like the linkage  :-\ My daughter has just had her gear linkage replaced on her corsa and its solved very similar issues  :y
PAULCDX
Thanks for the replies,
I'd been advised it could be the linkage or gearbox oil issue but tbh I haven't checked the level ( don't know how to lol  :-[  ::) )
Is the linkage an expensive fix / easy to do ?
Thanks  :y
Quote from: Tall Paul on 06 October 2013, 18:59:46
Thanks  :y
Martin will tell you its easy  ;D Not expensive and just a bit awkward to fit but do able  :y
martin42
It was easy for you,standing there whilst i was strugging to remove the old part and err assemble the new part the correct way around and adjust it to get the gears lol
Mite be worth you sending martin a pm if you cant fix it yourself  ;)
martin42
Quote from: The Mad mechanic on 06 October 2013, 19:04:28
I was sitting giving you encouragement  :P
PAULCDX
I defo can't fix it myself as I'm useless  ;D
I've just had a mooch on the bay, is this what I need? I think I have the F17 Box  :-\
http://www.ebay.co.uk/itm/370887339782?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
martin42
Buy a new 1 as you will need a new pin aswell
Yep , but i wouldnt buy second hand paul , the linkage fell to bits when it was took off the corsa . Best buy new if your going to keep the car  ;)
PAULCDX
Martin can you point me in the direction of where I need to buy one from or would it be the Dealer? ( stupid question I guess )  ::)
Am on the right track with the ebay link?
martin42
Search ebay for it should have new 1s on there but dont tell anybody your buying pattern parts lol
PAULCDX
I also have another issue  >:(
Car with the spanner light comes on all the time, previous owner told me it was code P1555 which points to the throttle body I think?
I'm hoping it just needs a good clean out  :-\
