Cleaning a DBW throttle body
Started by Webby the Bear, 07 October 2013, 22:52:04
Webby the Bear
Hey y'all, hope you're all mighty fine :)
When a car has DBW am I correct in thinking you shouldn't try and move the throttle butterfly open? if that's the case how'd you go about cleaning it fully?  :y
RIP Paul Lovejoy
Auto Addict
I'm not aware that you can't move the butterfly, I've done it several times on 2.2's.
See my guide.
I like red cars
Webby the Bear
Quote from: Auto Addict on 08 October 2013, 07:04:17
See my guide.
Oh. Must have come across wrong info.
Thanks mate  :y
RIP Paul Lovejoy
tigers_gonads
If you can get your hands on one of those hand held steam cleaning contraptions, they and a old toothbrush works a treat  :y
Webby the Bear
Quote from: tigers_gonads on 08 October 2013, 08:48:10
Thanks TG, yeah i use the toothbrush method ;)
i just could have sworn i watched a vid or read something where it said you shouldnt open the butterfly manually on a DBW. And as my ford fusion's needs cleaning and its a dbw i didnt want to damage it :)
RIP Paul Lovejoy
tigers_gonads
Quote from: Webby the Bear on 08 October 2013, 09:54:49
Done mine a couple of times now by slowly pushing it open with my fingers.
Never had a problem as I always gently push it shut again when finished  :)
Just make sure its swmbo's toothbrush  ;)
tigers_gonads
Quote from: Emd on 08 October 2013, 20:13:09
I'll remember that  :y ;D
After all, she did use one of mine to clean the dogs teeth last year   :o >:(
Quote from: tigers_gonads on 08 October 2013, 20:45:13
;D ;D
Webby the Bear
 ;D ;D ;D
Very productive day. Cleaned throttle body and moved it back no problem. was a bit dirty. cleaned the MAP sensor with contact cleaner also as apparently they're known to gather sh*t and set error codes/give trouble with starting....... may have something to do with the ''cage'' type housing its in  ::)
RIP Paul Lovejoy
