Author Topic: Chainsaw Part II  (Read 4188 times)
Chainsaw Part II
« on: 08 October 2013, 13:40:45 »
Unless somebody tells me that it's total crap.........I've decided on this one. :y
What's the worst that can happen?.... ::) ::) ;)
http://www.amazon.co.uk/gp/product/B00D7BNC1I/
Re: Chainsaw Part II
« Reply #1 on: 08 October 2013, 13:52:58 »
Depends how long you want it to last for and how good you are at working on two stroke carbs etc.
The issue I always get with the cheapo ones (I have to maintain some plus cheapo mowers and strimmers at the railway) is that there brilliant for one season, the next season they are troublesome, the third there a pain in the arse and for the fourth you either bin the bloody things or spend loads of time working on them.
At the end of the day, you get what you pay for.
« Reply #2 on: 08 October 2013, 14:00:13 »
I used to own a Yamaha RD 250 :y :y ;D ;D
I just need to clear half a dozen trees. Once done It'll be tucked up in the shed. :y
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #3 on: 08 October 2013, 14:17:44 »
In that case I would say go with the one you have found. You might even flog it after a few weeks use on Ebay. Keep it clean, have the chain sharpened  and keep an eye on screws and anything else that can vibrate loose. You will be fine. Of all the tools I use ( I spend weeks chainsawing in April each year) there is only one more dangerous tool and that is a large angle grinder. In other words be careful.
PS can you UTube the trees falling on your summer house for our pleasure?
« Reply #4 on: 08 October 2013, 14:17:53 »
It looks like a green version of mine. It works fine as long as you keep working it... As soon as I left mine for a period of time it became troublesome and, TBH, it may end up in the bin as it's not been run for a couple of years now so will almost certainly be more trouble than it's worth to get it running right again
brendan1983
  • Hampshire
    • Omega CDX Saloon
« Reply #5 on: 08 October 2013, 14:25:08 »
Just go to Argos - get the cheapest one - use it until it breaks or you finish the job and then take it back for a full refund.
One of my friends did just that - used it to chop down 8-10 trees, I think he went through 4 of them
« Last Edit: 08 October 2013, 14:27:06 by brendan1983 »
2003 CDX & Yamaha Thunderace
I_want_an_Omega
« Reply #6 on: 08 October 2013, 14:43:34 »
What's wrong with a cheap electric one?
Lidl had one for £55 IIRC - I bought one a couple of weeks back and used it non-stop for 2 days to cut up a couple of 10metre electricity supply poles into 6inch lengths which I then split.
It got through a couple of litres of chain oil - but did the job well enough  :y
« Reply #7 on: 08 October 2013, 15:11:01 »
I previously owned one, but it always struggled.
Hence my need forthe petrol version. :y
« Reply #8 on: 08 October 2013, 15:54:13 »
Who needs Which when you're an OOFer!!  8)  :y
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #9 on: 08 October 2013, 16:02:07 »
I bought one of those to cut up an old shed(not just any old shed though,carpenter built in the sixties with lots of wood used),it did well but like you I used a lot of chain oil ::)
other rides
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
« Reply #10 on: 08 October 2013, 16:16:16 »
I got an old Husqvarna which were taken over by Oregon which was not cheap at the time but it has given me 20 years of good service and is still going strong. It is used extensively every year to cut down and prune trees and cut the winter logs.
I don't know how the Oregons compare quality wise to the old Husqvarnas.
Just remember when you cut through a branch the diameter of your arm in seconds, they go through flesh and bone even quicker,  :o :o :o :o so treat it with respect.  :y
cnj
  • ludgershall
    • 2.2 Manual CD(51 plate)
« Reply #11 on: 08 October 2013, 16:41:34 »
its not just buying the saw, you should buy/hire chainsaw trousers as you only have one pair of legs, also do not ever use a chainsaw on your own as rods2 so clearly says they DON'T take prisoners, at least not often. if you have a limited use for this saw why not hire as I believe they have to supply the safety kit to go with it !
MR MISTER
« Reply #12 on: 08 October 2013, 18:10:31 »
Good idea  :y
Taxi_Driver
« Reply #13 on: 08 October 2013, 18:15:13 »
Good idea  :y
Its only 6 trees, whats wrong with a saw! Cheaper still  :y
But then again it is Mr 'minted' Opti  ;D
« Reply #14 on: 08 October 2013, 18:20:36 »
I wonder why he isn't sticking to the tried and tested method of a couple of his Serf's with axes and a double ended saw.......  :-\
