WANTED : Coolant Hose and clips from top heater connector.... 3.2 v6
Started by MaxV6, 09 October 2013, 17:50:26
MaxV6
omegod
Try Henryhubbard, I sent him a complete set off my 2.6 after his oil cooler went, not sure if he used them all !
Is the top one the curly one ? I cant remember. ::)
Anyway,I have a curly one and a straight one (ooh er missus),so should have whichever one you need. ;)
MaxV6
brilliant....
is the hard plastic clip assembly all part of it ?   there seems to be a green bit of a plastic ring on the back side , towards the bulkhead, that's broken on mine....   about the size of a 3-4 inch cable tie
hopefully you  know what i mean,  coz i'm pretty sure i don't know what else to call it...
can you let me know price inc postage ?   cheers.
MaxV6
MaxV6
see that bottom picture....   the connector on the right hand side.....   that's where it's leaking,  there seems to be a securing ring on it that's failed.
can;t see a ring on that picture though....    (thanks rob!)
Neither of mine are like the one at the bottom Rob.I think that may be that my car had the winter pack (electric pump under the coolant reservoir). ? If that's the case,I will need to know if Max,s car is the same.
Hard plastic connector is all part of the hose Max.Iirc theres a guide for removing / replacing them. Ive seen the green plastic ring you mentioned on some hoses.I think it may be used for fitting them at the factory ? Not certain though,hopefully someone else can confirm.
Maybe I should take a pic and post it up so you can compare Max.
Quote from: MaxV6 on 09 October 2013, 18:22:15
Yellow, right of pic at end of pipe
Quote from: Albitz on 09 October 2013, 18:23:55
Waste of plastic ;)
This is the one I have. Pretty sure its from a var with the winter pack,and the one Rob posted is from a car without winter pack.
If yours doesn't have winter pack,then you need one the same as the one in Robs pic - I think.
Quote from: Albitz on 09 October 2013, 18:32:39
If yours doesn't have winter pack,then you need one the same as the one in Robs shed - I think.
Fixed that for you ::) ;D
I hought they pics were from your library collection. ;D
In that case - PM Max. ;)
