Getting Omega back together...
Started by Webby the Bear, 09 October 2013, 18:24:21
Webby the Bear
Productive day today.
Got broken studs out of the cylinder head, refitted all cams as I wasn't happy with the cam seals sticking out a bit..... fitted cam seals first (as suggested by mark) and I can confirm they should be flush  :y
Thermostat/upper rad hose in position (although not bolted down as I've misplaced the new 'o' rings I purchased  ::) lucky they're only a few pence.
rear cover on.
cam sprockets on and torqued up.
cams timed up and locked in place.
crank moved up to tdc and locked in place.
torqued up exhaust fannymould bolts...... how I did it i'm not sure as the access is very poor   ::)
so left to do (roughly)....
zip up the down pipe to fannymould nuts
fit cambelt
reconnect electric connections
cam covers
inlets and manifold
pulleys and drive belt
trumpets and air box
a lot to do but at least I can see the light at the end of the tunnel  :y :y :y :y
ps, if it all goes tits up when I start her up i'm scrapping it and getting a mark IIII Astra!!!  ;D
RIP Paul Lovejoy
martin42
O rings were in big box,sorry forgot to tell you as they were blown across next doors garden  :y
Webby the Bear
Quote from: The Mad mechanic on 09 October 2013, 18:53:58
Yeah I thought they were too... (the big box that the HGs came in)..... but nope, they've vanished  ::) i'm forever putting stuff down in a ''safe place'' and then not remembering where that place is.
To be fair to me though I've kept track of most things. only things i'm missing are the two bolts to nail the stat in..... but I saved loadsa bolts from ralf so should be ok  :y
RIP Paul Lovejoy
You always have lots of bits left over , i got loads .. mainly broken bits ;D Or was that from the pug  :-\ Well done mate  :y
Webby the Bear
Cheers steve. just really want it back running now. missing it very much. I like my ma's ford but it diesnt drive like the big v6  :-X
RIP Paul Lovejoy
Whats happening with the rebuild  ??? ??? ::) ;D Mind you its nasty weather to be working outside  :(
Did all the cam bearing caps go on in the correct locations? They are numbered / sided :y
Webby the Bear
MaHOOsive thanks to TB for his assistance today. Cambelt on and all covered up. TB popped the belt on with nay trouble at all. Really good guy  :y :y :y :y
I've got an opportunity here.....
MOT runs out on the 14th..... can I get it back on the road on the 14th so I don't have to SORN it at all? .............. going to be a long weekend  :y
RIP Paul Lovejoy
Webby the Bear
Ps, as i'm pretty broke can I re-use my cam covers? They were genuine and they seem pretty pliable still.
RIP Paul Lovejoy
henryd
Quote from: Webby the Bear on 12 October 2013, 13:04:50
When I fitted 3.0 cams to mine I used the gaskets again but they were only a few months old,it didn't leak so try it,just "bear"in mind that they could ;) :y
other rides
What the worse that will happen? They'll leak and you'll have to replace them. So not much harm in trying.
*IF* you do reuse, keep a very regular eye on the plug wells, as you don't want to shag plug leads.
Quote from: TheBoy on 12 October 2013, 15:32:09
Not my car ;D They'll leak and you'll have to replace them. So not much harm in trying.
Webby, are the cam bearing shells in the correct orientation?
Quote from: Webby the Bear on 12 October 2013, 12:57:59
Nice one  :y
Webby the Bear
Quote from: JamesV6CDX on 12 October 2013, 17:32:13
Yes mate, I kept them in order when I removed them from the heads  :y
Ok, so went out for round two today after the F1 highlights.....
Wiring all back together including those tricky earths on the side of the dis module. cable tray back together. put two new o rings on stat pipe, fitted that and torqued that down. sandwich plate bolted and torqued. front cam cover on. aux belt tensioner fitted. front cable tray fitted. cam sensor fitted. PAS bottle refitted.
only a couple of issues.....
  • Stat pipe is quite loose to the stat housing with the new o rings in place. I can literally pull it off by pulling the hose from the 'b' bolt end. what can I do to make it a tight fit? I remember pulling the one off ralf and his had a loada sealant in  :-X
    • Aux belt tensioner is catching on the belt cover. the pulley that is. I have fitted all 5 bolts in the belt cover (inc. that one that's in the top left corner) and its tight yet the pulley still catches. any ideas  :-\ i'm wondering if it's warped from the explosion?  :o
      • pas reservoir empty  ??? ??? ??? ??? ??? ??? no idea how as we didn't empty it. and I cant find a pool of pas fluid  ??? ??? ???
        • I've accounted for all pipes and electrical connections thanks to TBs guidance. however one i'm missing...... the little vac pipe that attaches to the inlets (fuel regulator?)....where does that then attach to from the inlets?
        Other than that i'm going to whack on the old CC covers and touch wood it'll be done tomorrow  :) :) :) :) :) :) :)
RIP Paul Lovejoy
