newbie with a quick question :)
Started by chrisnoonan, 10 October 2013, 18:10:32
chrisnoonan
well lads new to the site..loving the site great info on it..:)...bought a 2.5td omega recently...just have a quick question there is something realy confusing me....the engine in the omega in a 6cyclinder 2.5td engine...its in a 2000 omega....i was told this engine is from bmw....like the same engine in the 325 e36 bmw....just wondering is this true cause im looking for performance mods...
Thanks Chris
Keith ABS
  Hi, Welcome. Dont know what BMW models are what but yes it is a BMW engine. There is a chip up grade to get it back to the BMW power output as it was detuned for Vauxhall by 50bhp. I also have a 2000 2.5TD but an estate with auto box
Keith B
As Keith said it can be chipped for more grunt,but if its an auto you will want to change the gearbox from AR25 to AR35,otherwise the torque will have the box for a light snack.
Welcome to OOF. :y
chrisnoonan
she is manual so its all good :)....where would i be able to pick one of these tuning chips up as i need as much power as possible as im building the omega for drifting....:) also my uncle remaps td for a living would it be possible to use the chip and also remap it?
thanks for the info the greatly appreciated :)
MadMark73
Hello and welcome to the OOF!!!  :) :) :)
Cliffo B
Jusme
Under-steer is when the front of the car hits the wall, and over-steer is when the rear of the car hits the wall.
Power is how fast you hit the wall and torque is how much of the wall you take with you.
Beemer M51 TDS engine, just detuned.
Sounds like yours will have a 427 ECU, so there are some good maps out there. Just make sure everything else is in good working order first, as those BMW units can be quite fragile.
Either Omegatoy (our resident TD expert) or I can put you in touch with somebody who can provide some chip options - a fair few OOFers have these ones, including myself when I had a tractor Omega. There are some options on ebay, usually cheaper, but these seem hit and miss (mostly miss, based on the ones I've seen).
Hi and welcome to the forum   :y :y
Johnny English
C20NE - X25XE
x25dt
Keith ABS
  Definatly go with either Omegatoy or the boy for getting a chip. They have a lot of experiance with tuning these engines and wont steer you wrong.
Keith B
sandune
