Author Topic: Warning Light  (Read 1892 times)
stevenenglish
  • Essex
    • Omega 2.6cdx
Warning Light
« on: 14 October 2013, 18:42:46 »
Hello everyone small problwm, hopefully.
Omega 2.6 V6 CDX 2002 warning light on dash indicates car outline with spanner through, understand that this means electrical problem, thing is auto box when foot on brake pedal will not release the gear select lever, any ideas, causes and solutions available.
Re: Warning Light
« Reply #1 on: 14 October 2013, 18:44:37 »
Look until Maintenence Guides for Code Reading and Pedal Trick
Post up results :y
Re: Warning Light
« Reply #2 on: 14 October 2013, 19:30:05 »
.... thing is auto box when foot on brake pedal will not release the gear select lever, any ideas, causes and solutions available.
Could be either the solenoid itself on the selector, or more probably the switch on the brake pedal  :y
stevenenglish
  • Essex
    • Omega 2.6cdx
Re: Warning Light
« Reply #3 on: 14 October 2013, 20:39:33 »
many thanks, with solenoid under brake pedal any ideas on what it is type etc, how difficult to fit.
Re: Warning Light
« Reply #4 on: 14 October 2013, 20:59:53 »
No. The switch is on the pedal. The solenoid is on the gear selector.  :y
Brake switch from the dealers £25  :-\  :-\  :-\ .....  really can't remember how much (sure someone will know for certain  :y) and is straight forward to fit, as long as you can get into the driver's foot well  ;D ;D
Waits for RobG to post a picture of the switch  ::)  ::)  ::)  ::)
MaxV6
  • Oxford UK
    • 2.2SportPremium Jag est
    • Work related forums....
Re: Warning Light
« Reply #5 on: 15 October 2013, 01:34:54 »
You have a totally irrelevant PM .....   (just mentioning it in case you're not used to our private message system )
