putting dipstick back....anyone got a pic of the hole it goes in???
Started by Webby the Bear, 16 October 2013, 16:27:43
Webby the Bear
As above. with martin42 and we cant get it in  ::) no jokes please. anyone got a picky of where it goes :)
RIP Paul Lovejoy
Shackeng
Darth Loo-knee
I assume you mean at the top? It shares tge "B.stard Bolt" with the transfer pipe from the thermostat and the engine lifting bracket :y
martin42
Webby the Bear
cheers guys and massive thanks again to the mad mechanic  :y
yeah got a bit lucky with the dipstick..... put it in roughly where I thought it should go, gave it a wiggle and it went in the hole  :) bit of bashing with a hammer on a block of wood to get it in..... job done  :y :y :y
its soooo very nearly done. got to get the aux belt tensioner off as I think the front cambelt cover needs replacing as its rubbing against the tensioner.... think it got warped when it got hot. lucky I have a spare  :y
so...... downpipe bolts. then all the bits at the front. and its ready to start  :y :y :y
RIP Paul Lovejoy
You managed to get the dipstick tube out? HTF did you manage that, as buggered if I can remove mine ;D
Webby,you have just become the forum expert on the one thing no-one else knows. :y :D ;D
Quote from: TheBoy on 16 October 2013, 19:39:15
Is that the Royal 'I'?
::) ;D
Webby the Bear
not really sure.  :-\ iirc martin got it out using brute force as, if im honest, I don't have a lot of strength  :-[
what have you tried?
RIP Paul Lovejoy
Webby the Bear
Quote from: Albitz on 16 October 2013, 19:48:21
;D ;D ;D
martin got the thing out.... but I must take the credit for putting it back  ;D i'm not going to say it was luck..... just used common sense  ::) ;D ;D ;D
RIP Paul Lovejoy
Quote from: ex taxi al on 16 October 2013, 19:49:40
::) ;D
You've only had 1 go. I've proved myself to be a failure twice ;D
Quote from: TheBoy on 16 October 2013, 20:00:00
::) ;D
Even after we loosened it ::)
Webby the Bear
so how come its taking so much effort? as its only a couple of o rings to overcome  :-\ someone perhaps sealed it up???  :-X
RIP Paul Lovejoy
