Car Heater ''Boxes''
Started by Webby the Bear, 16 October 2013, 19:36:16
Webby the Bear
Evening gays, I mean guys. :)
I haven't done a mechanic school blog for this year... not cos I haven't wanted to but I just have a lot on.... lots of homework  ::)
however what I thought i'd do was do adhoc updates when something interesting comes up.
I love this level cos its all about testing.
got a heater box out of a car and we been testing the blower motors, resistors etc. but what id like to know is this..... what actual part is the matrix? and am I right that the following unit is known as the ''heater box''? obviously I understand that theres effectively a small radiator that heat is drawn from to the cabin. but just want to know the terms i'm using are correct. :)
the blor motor and resistor out for testing  :y
testing the resistor
ps, anyone got any stories about pulling out one of these boxes? this one wasn't so bad.... but I imagine some would be  :o :o :o ;D
RIP Paul Lovejoy
Rover heater resistors are dead easy to remove. Just as well, given that its pretty much a service item on them ;D
The small radiator is the matrix. ;)
Webby the Bear
Quote from: TheBoy on 16 October 2013, 19:37:39
cheers albs,
tb, we talkin about all rovers.. inc. the 25? ::) ;D :y
I take it its the same for most heater boxes...... dash out first?
RIP Paul Lovejoy
Some cars the whole thing just unbolts from the bulkhead under the bonnet. Which is nice.  :)
Webby the Bear
Quote from: Albitz on 16 October 2013, 19:46:05
looking at the positioning of the ''matrix'' in this box i'm thinking there'd be no way of pulling that out if it needed replacing. so most of the time do you have to remove the whole box just to get the matrix out?  ::)
RIP Paul Lovejoy
Quote from: Webby the Bear on 16 October 2013, 19:47:55
In the Carlton/Omega A the matrix just slides in from the drivers footwell. (the clutch pedal gets in the way on a manual)
The Omega B is almost identical but the centre console is in the way  :( (but it is made of plastic so easy enough to cut a hole in if you don't fancy removing it to change the matrix ;))
