washer pump
Started by darrenfos, 18 October 2013, 19:50:31
darrenfos
(2001 omega elite estate) hi all washers front and back are not working (headlight washers are working) i think the windscreen and rear are on one pump no noise from pump at all fuse is ok wipers work could it be the pump itself p/n 90508709 before i get a new one (cant believe it past its MOT when purchased the car 2 weeks ago) thanks Darren
omega is like marmite you know the rest
Quote from: darrenfos on 18 October 2013, 19:50:31
Washer pump for a F/L estate should be part #90585762 (twin outlet). Number you are quoting is the saloon
darrenfos
i have the part in my hand it sure is a estate help needed
Quote from: darrenfos on 18 October 2013, 19:59:30
......and it`s for a saloon
darrenfos
year i didn't ask for sarcasm i asked for help
Quote from: darrenfos on 18 October 2013, 20:05:34
Not being sarcastic, just informing you that if the pump you have at present is the same as the one in my pic, it`s for a saloon and not an estate
darrenfos
there is a 3 way t bar near the pump looks very original not like its been added
If pump is knackered with 12v applied you`ll need one of these
darrenfos
right just had further look sorry for being up tight omegas do this to u right first part is ok forget it that's my headlight washers the smaller pump appears to be the washers and it is a double its number is 090586632 that's the one not working
Quote from: darrenfos on 18 October 2013, 20:38:45
Vectra/Astra pump though works with most of the VX models. As I said, if pump doesn`t spin with 12v applied direct it`s knackered
Cheap enough on eBay, but as Rob says, make sure it's for an estate (or hatchback in the case of Astras, Vectras etc)
Again, as Rob says apply 12 volts to the terminals on top, it doesn't matter which way round because the pump just spins one way or the other to wash which ever screen, and see what happens.
darrenfos
its a estate so which one is correct 90586632 or 90585762 thanks
Believe RobG - he's not taking the p*ss ;)
Quote from: darrenfos on 18 October 2013, 21:46:40
What's in a number, other than the number of outlets from the pump?  ;) You need a pump with two outlets because it's an estate  :y
