Author Topic: Siemens vdo cdr 500  (Read 2193 times)
arth
  • CORDOBA-SPAIN
Siemens vdo cdr 500
« on: 20 October 2013, 20:17:38 »
Hi
Recently I have bought a used siemens vdo cdr 500 player, it has replaced my philips casette player. The siemens is working fine, I can hear the radio and the cd is working properly, but there is just one issue. The cd track and the radio stations are not shown in the mid tid panel.
My omega is a firts series 96 model  with big mid tid.
Is there any solution to this matter? or it is just the siemens is not compatible with the mid tid.
The mis shows blank in the upper part, it just showed some figures when I had to enter the code.
Thanks
Antonio
Re: Siemens vdo cdr 500
« Reply #1 on: 20 October 2013, 20:21:23 »
Early MIDs were 8 digit, later 10 digit.
CDR500 can be set to either with a key combination. I *think* its press and hold 2 and 4.
arth
  • CORDOBA-SPAIN
« Reply #2 on: 21 October 2013, 07:18:32 »
Mine is 8 digit mid tid. I have just tried pressing 2 and 4 and did not work. Might be another combination I guess
Antonio
« Reply #3 on: 21 October 2013, 08:16:03 »
Try:
ign on
radio off
radio on
After beep, release 2 and 4
arth
  • CORDOBA-SPAIN
« Reply #4 on: 21 October 2013, 09:09:51 »
Ok, will try later and let you know if I solved it.
This  morning I went to my local Opel service, it is not the offcial one but the owner and some mechanics used to be in the official service and they know my car pretty well
The did not know about the 8-10 digit and could not fix the problem, ask me to leave the car there and see how to solve it but I need the car today so I couldn't leave it there
My radio came from a Zafira, I do not know if that helps.
Arth
arth
  • CORDOBA-SPAIN
« Reply #5 on: 21 October 2013, 09:33:29 »
Try:
ign on
radio off
radio on
Just tried this and what happened is
First time mid tid panel showed STEP 9 after the bip but no solution, the second time showed STEP 10 and same, no solution,  third time again apperared step 9 etc..
Arth
arth
  • CORDOBA-SPAIN
« Reply #6 on: 21 October 2013, 09:55:47 »
Problem solved!!  ;D ;D
The boy you were very near, 2-4 changes from American frecuency to European frecuency and 3-5 from 10 digits to 8
Source:
http://www.vauxhallownersnetwork.co.uk/index.php?threads/vdo-cdr500-tuner-problem.47022/
Rgds  :y :y
Antonio
« Reply #7 on: 21 October 2013, 17:38:01 »
Good news :y (about you resolving the issue, rather than my poor memory ;D)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #8 on: 21 October 2013, 17:45:09 »
Posting up VXON link, brave man  ;D ;D
arth
  • CORDOBA-SPAIN
« Reply #9 on: 22 October 2013, 09:47:38 »
Today I went to Opel Service and showed them how to solve this issue,they did not anything about this... 8)
And yes, thanks to T.B. I found the solution in the VXON forum  ;)  8)
Thanks again!
Arth
