Author Topic: turning over not starting  (Read 5605 times)
djhorner
  • isle of lewis
    • omega mv6
Re: turning over not starting
« Reply #15 on: 24 October 2013, 21:14:01 »
looks like it the timing slipped mayhave bent valves  ::)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #16 on: 24 October 2013, 21:20:44 »
that's confirmed?
RIP Paul Lovejoy
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #17 on: 24 October 2013, 22:28:22 »
Are ecu failures unknown on Omegas? I had one fail on a Senator. I had no sparks and did not know why. Swopped ecus with a similar 24 Senator and cured the fault.
  • Auckland
    • Mazda MPV
« Reply #18 on: 24 October 2013, 22:43:19 »
For several years the received wisdom has been that Omega ECUs do not fail.
Just recently I read that some of the car radios fitted to Omegas were reaching an age (or number of read write cycles) when their memory chips were failing.
The engine ECUs were made by a different manufacturer and should have been designed/specified to survive more arduous conditions, and for longer, than the radios. That said they are the same age............
terry paget
    • 3 Astras 2 Vectra
« Reply #19 on: 25 October 2013, 08:07:32 »
Was it running normally when last used until switched off?
I would check you have a spark by putting a spare plug into lead no. 1, laying it on the head and watching it while a friend cranks the starter. Is there a spark?
