Author Topic: turning over not starting  (Read 5592 times)
djhorner
  • isle of lewis
    • omega mv6
« on: 22 October 2013, 19:16:24 »
car keeps turning over and not starting so put new crank sensor on but still no joy is there anyway that numbers on coil pack are wrong ? we put leeds in order as follows from front nearest timing belt driver side 135 and passenger side 246
Re: turning over not starting
« Reply #1 on: 22 October 2013, 19:21:08 »
Correct. Are the leads correct on Dispack? Any codes stored.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #2 on: 22 October 2013, 19:25:13 »
Crank/no start.....Spark, fuel and compression needed. Double check ignition parts if you've tampered with coil pack  :y
RIP Paul Lovejoy
djhorner
  • isle of lewis
    • omega mv6
« Reply #3 on: 22 October 2013, 19:34:26 »
no codes stored when i put leeds in i went by numbers on coil pack can't remember them now , i have just heads done so if there is little oil where lifters are would that stop it starting ?
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #4 on: 22 October 2013, 19:35:36 »
Can you hear the fuel pump prime when you turn the ignition on? not unknown for the relay or pump to go wonky, I think the purple fuel pump relay can be swapped with it's neighbour to aid diagnosis
Webby the Bear
  • Northampton
« Reply #5 on: 22 October 2013, 19:35:51 »
Do you mean oil in spark plug wells? :)
RIP Paul Lovejoy
martin42
« Reply #6 on: 22 October 2013, 19:50:44 »
Means oil in the cam followers  ;D
djhorner
  • isle of lewis
    • omega mv6
« Reply #7 on: 22 October 2013, 20:13:38 »
aye oil it hydraulic lifters there is fuel getting pump as we crack the fuel line off the turned engine over and fuel came out
Webby the Bear
  • Northampton
« Reply #8 on: 22 October 2013, 20:15:27 »
lifters are meant to have oil in them  ???
RIP Paul Lovejoy
djhorner
  • isle of lewis
    • omega mv6
« Reply #9 on: 22 October 2013, 20:41:02 »
there is a little oil in lifters but if theres not enough would that stop it starting
Webby the Bear
  • Northampton
« Reply #10 on: 22 October 2013, 20:46:10 »
Sorry, I see what you mean now.... you were talking about a lack of oil to the lifters  ::) my mistake.
by cranking the engine unless im otherwise mistake will circulate the oil so oil should have reached there.
RIP Paul Lovejoy
symes
  • oxford
    • R reg 940 volvo
« Reply #11 on: 22 October 2013, 20:54:17 »
if fuel getting to engine--then has to be no spark--so coil pack or leads--
djhorner
  • isle of lewis
    • omega mv6
« Reply #12 on: 22 October 2013, 21:11:55 »
new leeds new sparks and there is power to spark plugs will be checking all tomorrow
  • Auckland
    • Mazda MPV
« Reply #13 on: 22 October 2013, 22:18:35 »
Lifters need full oil pressure to pump them up, just cranking doesn't generate enough pressure. When the engine first starts after a (re)build there should be mostly air in the lifters but this doesn't stop the engine starting (it does make a scary rattling noise until the lifters fill up though :o)
What may stop the engine from starting is having lifters that are already pumped up and are therefore holding valves open & killing the compression. This guide Cleaning and testing a hydraulic lifter describes the process of freeing up used lifters and preparing them for re-use.
mrgreen
  • Salzburg/austria
    • 2000 2.2 petrol estate
« Reply #14 on: 23 October 2013, 05:43:31 »
so with that said a compression test would tell you if you had this problem, but i'm geussing spark, something not plugged in e.t.c
Warning: Dates in Calendar are closer than they appear.
