radiator cooling fan
Started by ianley, 23 October 2013, 20:55:17
ianley
Hi folks.
I am new to the site and after some advice please. I have 2.2 dti i just bought, the engine fan is running all the time even with keys removed it will run for ages, the aux water pump is disconnected and if connect it drains the battery, could this be the cause ? I am a vw technician so now my way around things a bit but not come across this,found orange relay burnt out so replaced that but not resolved the issue, any ideas folks?
flyer 0712
Hi and welcome......you have put your question into the wrong section.... :y
Cliffo B
Hello welcome to the Forum :y
Best post your query in the 'General Help' section I'm sure you'll get lot's of help there :y
slowboy
Johnny English
C20NE - X25XE
x25dt
noel
brian36
sandune
Hiya welcome to the forum :y
Jusme
Hi, Welcome to the OOF.  :y
Under-steer is when the front of the car hits the wall, and over-steer is when the rear of the car hits the wall.
Power is how fast you hit the wall and torque is how much of the wall you take with you.
