Pages: [1] 2 3  All   Go Down
Author Topic: Tyre pressure  (Read 5562 times)
MR MISTER
Tyre pressure
« on: 25 October 2013, 15:12:45 »
What is the recommended tyre pressure for the heaviest omega. (3.2 with all the toys, I guess)?
And what would such an omega weigh?
MR MISTER
Re: Tyre pressure
« Reply #1 on: 25 October 2013, 15:19:50 »
I'm guessing the omega would weigh about the same as my bus, 2.2 tonne. The recommende tyre pressure on mine is 35 psi normal, 39 psi eco on 215/60/16's. 39 seems high  :-\
Re: Tyre pressure
« Reply #2 on: 25 October 2013, 15:24:24 »
Fr 41psi,  Rr 48 psi total max weight 2305kgs :y
chrisgixer
Re: Tyre pressure
« Reply #3 on: 25 October 2013, 15:31:44 »
Unloaded 32psi all round.
MR MISTER
Re: Tyre pressure
« Reply #4 on: 25 October 2013, 15:36:53 »
41 and 48 ???? Wow. :o
You sure you're not getting mixed up with your truck?
« Last Edit: 25 October 2013, 15:44:57 by STEMO »
MR MISTER
Re: Tyre pressure
« Reply #5 on: 25 October 2013, 15:37:48 »
That's what I guessed, 32 up to 48 is a bit of a leap.
Re: Tyre pressure
« Reply #6 on: 25 October 2013, 15:57:29 »
That was max full load pressure for an estate btw :y
MR MISTER
Re: Tyre pressure
« Reply #7 on: 25 October 2013, 16:16:43 »
Wouldn't like to try that on a slippery surface.
Re: Tyre pressure
« Reply #8 on: 25 October 2013, 16:23:44 »
http://homepage.ntlworld.com/andrew.reynolds983/Manuals/Omega2002Manual.pdf
pages 222 to 226 .....  :)
MR MISTER
Re: Tyre pressure
« Reply #9 on: 25 October 2013, 16:41:56 »
So....2.4 bar estate rears fully laden. 2.7 still seems high on mine. I might get good fuel economy but wearthe middle of the tyre out. ;D
2.5 I think.
Re: Tyre pressure
« Reply #10 on: 25 October 2013, 16:56:29 »
Run our f/l Estate on 34psi front, 36psi rear - same as on old Elite Estate.  Find this suits our needs ;)
Re: Tyre pressure
« Reply #11 on: 25 October 2013, 17:27:49 »
I run 16 and 17" tyres at that pressure, absolutely fine in the snow :y
18"s I run at 35/38 as they have a bit less give...
Trucks run at 110/100 or there aboots :y
MR MISTER
Re: Tyre pressure
« Reply #12 on: 25 October 2013, 17:34:23 »
[quogoing to Liverpool nextthor=ex taxi al link=topic=118830.msg1507693#msg1507693 date=1382718469]
[/quote]
I'm going to Liverpool next week, I'll try the 'eco' pressure and see what I get.
Re: Tyre pressure
« Reply #13 on: 25 October 2013, 17:37:47 »
Don't forget the jack and bricks locking wheel nuts :y
cnj
  • ludgershall
    • 2.2 Manual CD(51 plate)
Re: Tyre pressure
« Reply #14 on: 25 October 2013, 18:52:12 »
I used to run my old cdx on 36psi front and 40psi rear, failure to keep those pressures caused excessive tyre wear and early changes, it was running as a hackney carriage at the time !
Pages: [1] 2 3  All   Go Up
