Author Topic: Torque setting  (Read 2092 times)
tooleater
  • Rickmansworth,  Herts
    • Go faster Black MV6 Man
Torque setting
« on: 26 October 2013, 09:53:36 »
Morning guys just getting geared up for Thermostat change, could do with following torque settings, Spark Plugs. Sandwich Plate. Thermostat housing to block.
cheers :y :y
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
chrisgixer
Re: Torque setting
« Reply #2 on: 26 October 2013, 10:01:48 »
tooleater
Re: Torque setting
« Reply #3 on: 26 October 2013, 10:20:25 »
Cheers Chris have a good study of that more than once, but concerned about Thermo housing, O ring to make seal any other sealant required and my teng 3/8 torque wrench lowest setting 15 ft lbs. what should I torque the thermo housing bolts to ;)
Shackeng
  • Ramsbury
Re: Torque setting
« Reply #5 on: 26 October 2013, 10:31:26 »
Read the link that's been posted here and in the other ABS ECU thread just down from this  ::)
tooleater
Re: Torque setting
« Reply #6 on: 26 October 2013, 11:02:46 »
Thanks for that Tunnie, not wanting to upset anyone Im still none the wiser. I have watched the link over and over again, I sure heard I him say "Thats them torqued down" but to what, its not in the final list either. Haynes manual with my computer ;D ;D. I like to get the job done before clocks go back :y
Re: Torque setting
« Reply #7 on: 26 October 2013, 11:08:09 »
Watched? Try reading it  ;D
Replace seals on transfer pipe (if not replacing transfer pipe), and apply a smear of grease or vaseline to them.
Pull back the transfer pipe to allow room for thermostat to attach to engine block, and torque it to 20Nm, then push transfer pipe into thermostat
http://images.omegaowners.com/images/guides/v6_dbw_thermostat/MVI_4876_conv.html
On this 3.2, the B-bolt only holds tarnsfer pipe and engine lift bracket. Others, the B-bolt goes through transfer pipe, dipstick, engine lift bracket.
Shackeng
  • Ramsbury
Re: Torque setting
« Reply #8 on: 26 October 2013, 11:12:37 »
Thanks T :y :y :y :o :o :o :-X
tooleater
Re: Torque setting
« Reply #9 on: 26 October 2013, 11:23:18 »
Now I do feel like a numty mate :-[ :-[ :-[ to much bloody concentration on  videos and not enough on what was written. Oh look its raining what could possibly go wrong ;D
Re: Torque setting
« Reply #10 on: 26 October 2013, 11:25:37 »
No problem  ;D ;D ;D  :y
  • Auckland
    • Mazda MPV
Re: Torque setting
« Reply #11 on: 26 October 2013, 11:27:18 »
It shouldn't need any extra sealant but I find that differential corrosion occurs between the alloy thermostat housing and the iron block so I give it a smear of Hylomar which seems to do the trick :y
tooleater
Re: Torque setting
« Reply #12 on: 26 October 2013, 11:29:31 »
Thanks Andy, just waiting for sky to clear then job on  :y
amba
  • Medway towns
    • German V6
Re: Torque setting
« Reply #13 on: 26 October 2013, 12:08:08 »
When I did mine last year I ran a thin bead of grey oil cooler plate sealant ( only because I had it to hand as did cooler at the same time)around the outer edge just to be totally sure, as that very thin rubber 0 ring didn,t inspire me with the confidence it would fully seal up.
All has now been coolant tight for over 40k . :y
