Author Topic: Cant open rear door  (Read 3480 times)
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
Cant open rear door
« on: 27 October 2013, 08:29:24 »
Having a real problem opening rear offside door,(permanently locked).
has anybody got any ideas how to open,as i cant even get the door card off with the door locked  >:(
Thanks in advance ;)
Re: Cant open rear door
« Reply #1 on: 27 October 2013, 08:31:07 »
What happens when you pull up the door pin?
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #2 on: 27 October 2013, 08:42:43 »
Not trying to open door from inside with child locks on are we :D
Hoof'land storeman.
noel
  • frome somerset
« Reply #3 on: 27 October 2013, 08:50:30 »
just solid in lock down position
noel
  • frome somerset
« Reply #4 on: 27 October 2013, 08:53:50 »
no im not but thanks  ;) don't use child locks as my kids are 15 and above :)
« Reply #5 on: 27 October 2013, 11:10:43 »
You can sometimes get them to open by pulling the door pin as you unlock via the fob  :-\
noel
  • frome somerset
« Reply #6 on: 27 October 2013, 11:31:14 »
Think im going to have to try brute force and ignorance andy  :-\
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #7 on: 27 October 2013, 12:08:30 »
I had similar problem with front door the pin would not lift by hand.   I used a pair of pliers and levered on the door and the pin came up,
« Reply #8 on: 27 October 2013, 12:10:10 »
Easier done from outside, window down and just pull straight up with mole grips :y
Andy663
  • Ayrshire
    • 3.0 MV6 (2000)
« Reply #9 on: 27 October 2013, 13:29:30 »
Have you tried opening the inside and outside handles at the same time?
noel
  • frome somerset
« Reply #10 on: 27 October 2013, 16:28:37 »
thanks for the suggestions, think I will be brutal with the mole grips ;D
« Reply #11 on: 27 October 2013, 19:06:03 »
Won't work if it's deadlocked as the linkages are disabled :y
martin42
« Reply #12 on: 28 October 2013, 15:16:14 »
Just weld up back doors and front then remove side glass windows,paint it orange and you have your own general lee  ;D ;D ;D
