Pages: [1] 2 3 4 5 6 7   Go Down
Author Topic: Radiator replacement  (Read 9545 times)
« on: 27 October 2013, 11:21:10 »
How much water does it hold (not measured yet, approx 1.4m, not sure on height, upstairs so slightly taller, single rad)?
Can I get away with closing the valves either end (one is only a thermo one), rather than drain down, as I lack a hose to drain.
Are the nuts a std size, if so what, as I'll need to buy a spanner.
Guess what my task is today :(
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: Radiator replacement
« Reply #1 on: 27 October 2013, 11:25:36 »
Certainly you can get away with valve closure, borrow Mrs TB's small baking pan and place under one of the valves, and after ensuring both valves closed, (you may have to remove the thermo top unit to ensure that is shut,) crack one connection slowly and gradually drain it into pan (do not open bleed valve until necessary to get all the water out). When removing rad, remember there will still be a few ml of, usually horribly black, water/sediment still remaining.  Nuts are about 21mm, not always the same.
After fitting new rad with a pressurised system, recharge to required, 1 bar, pressure, and bleed system as necessary, non-pressurised will top up from your header tank, but bleeding is still required. HTH:y
« Last Edit: 27 October 2013, 11:35:40 by Shackeng »
« Reply #2 on: 27 October 2013, 11:33:19 »
Ah, how do I remove thermo unit... ...I was just gonna turn it to its lowest setting  :-[
« Reply #3 on: 27 October 2013, 11:33:52 »
Also, just ptfe tape on the new threads, nothing more?
MR MISTER
« Reply #4 on: 27 October 2013, 11:34:10 »
I can't see Shackeng's reply until I quote  ???
It's there now :-\
Shackeng
  • Ramsbury
« Reply #5 on: 27 October 2013, 11:37:43 »
Sorry kept adding bits.  I use ptfe tape and Jet-blue, as there is nothing worse than a slight weep. The thermo top should be removable depending on make, if not, it should close at coldest setting. :y
Shackeng
  • Ramsbury
« Reply #6 on: 27 October 2013, 11:40:24 »
Is your system pressurised or header tank?
« Reply #7 on: 27 October 2013, 11:41:33 »
Its a proper system :P
So header tank :y
SIR Philbutt
  • Rochdale - Manchester
    • 03 2.2 CDX LPG estate
    • PJB Home Services
« Reply #8 on: 27 October 2013, 11:43:47 »
valves close off the system not the rad you will have to drain it
OR
put some old towels under each end,
close valves (TRV must be past * to be off),
place something under bottom of rad (i use my dewalt drill box)
loosen the nuts off the rad,
lift rad off hooks and tilt until top of rad is on floor
remove valve connections and lift rad so upside down (make sure bleed is shut)
You can then empty contents outside
Ta Daaa  :y
Practice before doing you have to be quick
Make sure pipes have some movement so that you can lift offf hooks
HTH
Phil
WARNING - just seen - removing the thermo valve top OPENS it not shuts it
« Reply #9 on: 27 October 2013, 11:44:28 »
Also, no option to undo bleed valve - thats the reason it needs replacing, its all swollen in that area, looks like rusted under the paintwork, and already showing the signs of a gentle weep.
Noticed, as I thought I should just test the heating before I allow her control back to the thermostat ::)
MR MISTER
« Reply #10 on: 27 October 2013, 11:46:21 »
Sounds like it's been weeping for a while, that's why it's rusty.
« Reply #11 on: 27 October 2013, 11:46:56 »
shitty microbore pipework, so should be some flexibility in pipes.
Screwfix rad OK, seeing as they are open Sundays? Persumably Rad doesn't need painting etc?
Shackeng
  • Ramsbury
« Reply #12 on: 27 October 2013, 11:49:48 »
So header tank :y
You will know if the valves are closed, if you start draining with Mrs TB sat in the loft next the header tank, she will shout stop, when the fill valve opens if you haven't switched both rad valves off correctly. ;D ;D ;D
« Reply #13 on: 27 October 2013, 11:50:22 »
I reckon its rusted from inside, as its swollen along top, (presumably) rusted under the paint. Dried rust marks at bottom, with is what makes me think its weeped. No stains/marks on carpet.
May have bee like this for a while, as there was a desk hiding it, which has only been moved to allow those useless retards at Evander 6 trips to fit 3 windows.
Shackeng
  • Ramsbury
« Reply #14 on: 27 October 2013, 11:51:24 »
Yep, they have different grades. :y
Pages: [1] 2 3 4 5 6 7   Go Up
Page created in 0.026 seconds with 14 queries.
