Author Topic: Coolant leak  (Read 2007 times)
danzigfan
  • Jesenice, Slovenia
    • Omega 2.5V6, 3.0V6
Coolant leak
« on: 28 October 2013, 03:17:20 »
Hi guys, my miggy has a quite major collant leak on the big upper hose where it connects to radiator. The plastic part which goes into the hose isn't cracked so I believe it could be a clip a bit "tired" after all this years. Can I try to replace it with a jubilee clip? I know it should be flexible clip but is it worth trying?
Thanks, Stan
Re: Coolant leak
« Reply #1 on: 28 October 2013, 09:22:32 »
It can't hurt to rule it out :-\
danzigfan
Re: Coolant leak
« Reply #2 on: 28 October 2013, 09:36:43 »
I hope it's a cheap fix and nothing else will appear...I need to watch for overtightening the jubilee clip  :-X
Re: Coolant leak
« Reply #3 on: 28 October 2013, 09:38:51 »
Could always go oversized, and use a piece of old hose to act as a pad between the clip and the pipe :-\
danzigfan
Re: Coolant leak
« Reply #4 on: 28 October 2013, 09:45:55 »
Not a bad idea...better prevent than cure
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Coolant leak
« Reply #5 on: 28 October 2013, 10:51:30 »
Or wrap some Amalgamating Tape (gently stretch it as you wrap around) around the hose before you use the Jubilee Clip  :y
danzigfan
Re: Coolant leak
« Reply #6 on: 28 October 2013, 14:05:43 »
Original clip was so flexible i could pull it down the hose with fingers only, replaced it with two jubilee clips and now I'm waiting for a leak under the bonnet, which is my miggy's signature whereever I go....
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: Coolant leak
« Reply #7 on: 29 October 2013, 07:06:59 »
I had a similar leak on a 2 litre Omega. It turned out to be a crack in the radiator plastic tank pipe junction. Failed to repair it, cured by fitting new radiator.. Good luck!
