2.2 lambda WTD
Started by omegod, 28 October 2013, 20:57:21
omegod
As above I need a front o2 sensor for 2.2 petrol, known good obviously !
biggriffin
Go to local factor and buy a universal lamda and solder on the old plug.
cut old plug off leave enough wire so its a bit longer than the original cable,put sum shrink tube on cables,solder wires together,then put shrink tube on.
job done. :y
Hoof'land storeman.
zirk
Are the 2.2's 3 or 4 wire?
omegod
Quote from: biggriffin on 28 October 2013, 21:48:06
job done. :y
Pattern  :o :o :o :o :o, I was thinking OE, even used, would be more reliable?
Arent they the same as V6 lamdas ?  :-\
Good pattern is fine  :y
Although I do have number of used OE ones, get them from breakers when they pop up as spares :)
Quote from: Albitz on 29 October 2013, 19:19:14
Different part number
omegod
Quote from: tunnie on 29 October 2013, 19:45:30
Yeah I sent you 4 V6 ones not long ago ;D If you have a decent 2.2 one give me a shout
Quote from: omegod on 29 October 2013, 19:56:24
Will do  :y
Don't buy a pattern one. Buy genuine Bosch only. Try Lambdapower for a good price.
biggriffin
Quote from: VXL V6 on 29 October 2013, 23:00:06
NGK one just as good.
Hoof'land storeman.
Quote from: biggriffin on 30 October 2013, 10:52:08
Yep agree with that. Don't rate any others though.
