Author Topic: 2.5td famous oil in intercooler track leak  (Read 1857 times)
conalnugent
  • n. ireland
« on: 29 October 2013, 12:41:15 »
I know this is a fairly common issue. Id say its a safe bet to say its a seal in the turbo past its best. So anyways question being I assume its time to rebuild the turbo also whats the best way of cleaning thr oil out of the jnlet manifold and pipe work etc
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: 2.5td famous oil in intercooler track leak
« Reply #1 on: 29 October 2013, 13:46:21 »
I don't understand the title, but I clean my inlet plastic pipe with carb cleaner. The manifold has to stay dirty until I change Gloplugs, when it has to come off. HTH
conalnugent
  • n. ireland
« Reply #2 on: 29 October 2013, 16:43:33 »
The oil that gets into the intercooler pipe work, how does it get there and how can it be cured
« Reply #3 on: 29 October 2013, 17:53:52 »
I removed the inlet manifold and cleaned it with a cheap bog brush and loads of nitromors
Shackeng
  • Ramsbury
« Reply #4 on: 29 October 2013, 18:59:16 »
Perfectly normal, I've had my TD from nearly new, and there has always been a bit of oil in the intake As part of emission controls, crankcase gases are fed back to the inlet, bringing with them oil vapour which condenses on the cooler surfaces of the inlet ducting. (I think that's right anyway) :y
conalnugent
  • n. ireland
« Reply #5 on: 29 October 2013, 21:37:04 »
Ah yes. Forgot about that pesky crank breather.  Must get that rerouted etc
