Author Topic: Engine light help!!  (Read 940 times)
Richiel_7
  • Luton
    • 2.2 ecotec auto 2.2 Omega
Engine light help!!
« on: 31 October 2013, 17:59:18 »
Hi all,
After getting cheesed off with electrical gremlins on my Alfa's I have switched to a lovely 2.2 auto Omega.
Having a small gremlin which I need advice on.
On start up the car can sometimes take longer than normal to fire - it is accompanied by the engine light and check auto gearbox message. On turning the ignition off and trying again, car fires quicker and all is fine. Even if I drive with the fault showing, the car drives perfect - no gear issues or hesitation etc. Also if I correct the fault by refiring the car - the fault never appears while driving - only at start up.
Fault code showing is P1781 - engine torque signal circuit.
My gut feeling sends me to the cam sensor as it is a start up fault - but I only had this changed 3 weeks ago. The reason I had the sensor changed is because sometimes the engine light would come on whilst driving (not just from start up like it does now) although then, I never pulled up a fault code and don't know if the check auto gearbox was showing because it was before I changed my faulty header tank and the check coolant light was always on!
The cam sensor I bought was not GM but was (I'm told) a reliable make - FACET.
My question is, where do I go from here. Could I have two duff sensors or is it more likely a fault elsewhere?
Any help gratefully received!
« Last Edit: 31 October 2013, 18:02:47 by Richiel_7 »
Re: Engine light help!!
« Reply #1 on: 31 October 2013, 18:03:24 »
Pattern cam sensors not good news mate - go for genuine Vx ;)
« Reply #2 on: 31 October 2013, 18:11:54 »
Agreed. I would bet a genuine GM sensor will cure your problems. :y
Richiel_7
  • Luton
« Reply #3 on: 31 October 2013, 18:22:12 »
Okeydokey. Thanks for the responses!
I'll trog down and try to "trade" in the duff one for a vx tomorrow. Why do they sell these things if they don't work - it was still £40!
I'll let you know how it goes!
Richiel_7
  • Luton
« Reply #4 on: 31 October 2013, 18:38:15 »
Hmmm. Would I be right in my assumption that people advertising genuine Vx ones at cheap prices on eBay, aren't actually genuine?
GM use siemen, right? Would a siemen one do or should I ONLY go to a vauxhall dealership?
Thanks
« Reply #5 on: 31 October 2013, 18:50:54 »
Accept that most branded stuff on Ebay is fake.
For that reason, I'd get one from a dealer, or if 3rd party, ensure it has the GM hologram on the sealed packet.
Richiel_7
  • Luton
« Reply #6 on: 02 November 2013, 10:50:57 »
Hi all - just an update.  :D
Success!!!
The hologramed GM part may have been expensive at £80 but it did the job. No more fault lights. Start up feels smoother too. I shall now avoid aftermarket sensors forever!
Thanks for the advice.
« Last Edit: 02 November 2013, 13:44:11 by Jimbob »
